Mazda CX-9 Rear Parking Assist
I'm buying a CX-9 Grand Touring FWD with Nav and RSES. The one feature I had wanted in a car that isn't available on this one is the rear park assist (the sensors that beep as you approach something in the rear). The dealer has offered to add that feature for me, although he thinks the back-up camera is a better tool.
My question is: Do you think it would be bad to add the rear park assist post-factory (it isn't available from the factory at all) since I'll have the back-up camera? My thinking is that the camera will show me objects are there but won't show me how close they actually are.
The dealer says that the sensors will just be two black circles the size of quarters on the back bumper and that they'll be hooked up to the speakers. He's never seen it done on a Mazda, although they used to do it at his previous dealership (I forget the kind of car).
I have to give him a decision immediately, so I'd appreciate some input ASAP. It won't affect the price of the car, by the way.
Thanks very much.
Thanks very much.
After an exhaustive search, I decided I will place an order for a GT with no add on packages since I could not find one with Liquid Platinum with a Sand interior. However, I do need the Back Up camera and realized I could order the Back Up Camera w/Auto-Dimming Mirror Display without the entire Assist package (I am OK with buying the best Garmin package out there for Nav since the one that comes with the package is very mediocre I heard). I also want a GT because, I want the Blind Spot monitoring system and Blue Tooth for sure.
So my question to the good folks on the forum.
How good is the Back Up Camera w/Auto-Dimming Mirror Display? Am I making the right choice? It appears smaller in size since it is in the mirror and my belief is that it can only help and especially since it is a factory accessory and is the recommended accessory with the Touring model.
Also, is the IPOD jack standard on GT or do I have to order the 6 CD changer package (without the moonroof package. Moonroof packages comes with extra speakers too) ?
Finally, How long does it take from the time of placing the order to receive the vehicle? I heard dealers tell me from 4 to 12 weeks.
Too bad that there aren't many GTs out there without any packages.
Please advice.
Where are you located? The GT platinum with sand interior with Blind Spot Monitoring is extremely hard to find because around the time they started offering BSM, they stopped making sand interiors with the platinum exterior.. I just bought a Plat/Sand yesterday after weeks of searching, but it did have the Assist Package. Have you gone on mazdausa.com and gone through their vehicle inventory? That's how I located my car, which was at a dealership 300 miles from my home. You probably already have done this, but if not, try widening your search area by putting in other cities in your state. Chances are your local dealer will be happy to get the car for you, or you can travel to get it if it's not too far. I'm pretty sure I came across some in my search that didn't have the GT Assist Package.
Unfortunately, I can't help with the mirror/camera question.
Good luck!
Ultrasound:
pros: still work in the darkness. easy to install yourself (in a couple of hours), cheap (part from eBay at $50 + $10 for display if needed).
cons: false alarm when ice, snow or water on the sensors (it may happen more often for folks living in snowy area), black circles on the bumper (don't get the painted ones 'cause they are more prone to false alarm)
Anyway, I will get a GT AWD with backup camera, and I always install ultrasound sensor for all my vehicles.
As for ordering, a local dealer told me he had placed an order for a CX-9 back in mid-November. The car was built a month later, and is now on the boat. So by the time it is delivered, it might very well be 3 months.
While I assume the visible parking guides are not an option on the CX-9, is the distorted view a common experience or was the camera installed improperly. If this is common, this is a major design flaw for such an expensive option.
The display is a little off-center, so it leaves something to be desired for visibility, however the Nav based unit was the same. I am going to ask the dealer if there is a way to adjust the camera to give a better view...
Let me give you a hint... "oil" (cooking oil will do fine)
Rubber has very high friction. It is very tough to get cable through. Anyone who mod cars frequently knows that oil is your best friend to run wires thru rubber boots.
I have done backup camera to my 2005 Prius. The job was similar. Video cable thru the rubber boot to the hatch.
Were the instructions for this kit cover the CX-9 exactly or just generic?
If it is detailed, I would love to see a copy of it.
I recently got the camera installed at the dealer. Is the camera usually tilted more towards the drivers side? I can see the driver side corner very clearly but the passenger side rear bumper corner is not visible. Is the camera adjustable at all? The camera is installed on the left of the liftgate handle so it is already more towards the drivers side. Thanks in advance!
