Pontiac Grand Am Overheating
in Pontiac
I changed the thermo,water pump,heat sensor,flushed the rat.and the car still runs hot.any more sugg.thanks
http://www.aa1car.com/library/overheat.htm
When refilling the cooling system, air can become trapped under the thermostat. This will form a steam pocket that prevents the thermostat from opening and may cause the engine to overheat. Some cooling systems have one or more bleeder valves that can be opened to vent air from the system while refilling the system. If your cooling system does not have a bleeder valve, you can drill a small hole in the thermostat as shown. This will allow air to escape past the thermostat so it is not trapped inside the engine block. Some thermostats come with a similar feature called a "jiggle valve." There is a small hole in the thermostat with a pin that allows air to escape.
Car Problems:
1. heater is not working. There is no hot air going into engine just cold.
2. White Smoke is coming from exhaust pipe
3. coolant is coming out of the coolant/water reservoir from where the cap is located.
4. engine temperature gauge is going into overheating zone
5. the low coolant light in car is always on even when the car coolant is filled completely
Well fellow Grand Am owners I guess I have been pretty fortunate. Up till now I have had no problems with mine. But alas yesterday I saw fluid leaking under my car. I was astonished because I have never had even a drop of any kind of fluid. Ok I did the taste test it is definately coolant. After a thorough inspection I found the coolant was coming from a drain hose about 6 inches long and curved, slightly left of center on the firewall. I don't recognize the hose. At first I thought it was broken but was able to remove it and it seems to be made that way.
I drove the car this morning and it started to overheat but the air coming from the interior heating vents was ice cold. The carpet is not wet or damp but I am getting a coolant smell from the vents. I'm thinking the heater core is clogged at best, broken at worst. Any thoughts out there on this, does it sound like I am on the right track? Any help, advice or cheese to go with my whine would be appreciated!
Doug
1. With age, your coolant reservoir cap can no longer hold the pressure and allow coolant to overflow. The fix is easy: Get another cap and replace it.
2. A blown head gasket - so the air from the cylinder is pushing the coolant out. You can test this by have the reservoir cap open and let the engine run for 2 min. If there is any air bubble comes out from the coolant in the reservoir, you have a blown head gasket and if you can not do the work yourself, it is time to junk the car and move on...as a typical head gasket job will cost you over $1000.
Since my last post I decided to bypass the heater core just to see if the core was the problem. Took me about 20 minutes. Checked the coolant level and drove off hoping the engine would run at correct temperature. It did! I also ran it with the air conditioner on to load it and the temp stayed under 200.
Since I had no leakage inside the car I thought I would do a quick pressure check on the heater core. It held pressure even if one opening was not capped! I guess the core just got so clogged it would not allow flow.
I will still have to disassemble to replace the core but at least the overheating problem is gone. It is a little cold in the morning but hey this is San Diego.
After doing research I understand the repair manual is somewhat vague about replacing the core. Anyone know where I can get a good set of diagrams or a step by step procedure?
Again thanks for the replies
Doug
http://www.automotivehelper.com/topic672471.htm
I haven't done it myself. Before 1999 they recommended removing the entire dash for access, but it may not be necessary on later models according to these instructions. It's hard to believe that the core is completely blocked, but I guess it's possible..........
