2009 VW Touareg 2
VW has a new Navigation System coming out. It's called the RNS-510. The Tiguan will get it first then the rest of the 09 models. This new model has lots of features.
Touch Screen Operation
6.5"VGA 16.9 TouchScreen LCD
400 mHz CPU
Standard map display, or 2D or 3D
Audio Playback in MP3 or WMA formats
SD Card Slot for MP3 data which can be copied to the hard drive
30!! GB internal hard disk
Videos while not in motion. It will play both audio CDs and DVDs
The DVD Maps are from Navteq not TeleAtlas
CD Changer, IPOD Interface, Analog and DVB-T Tuners can be connected
Off Road GPS
http://www.lutschi.biz/album/RNS510/
The unit should be available later this year with the DVD maps. The maps will install on to the Hard drive
There is a made for touraeg version that fits in the dash opening. Only works on Touareg 2's. Touraeg 1's need an adaptor that isn't out yet. Thats from what I have heard. Also there is a premium bluetooth kit that works with it. Backup camera is a possibility too. US version will probably not get TV but will get Sirius Radio. Just wanted to let you know about it.
Non navigation Touareg's are getting a touch screen for 09. There will be premium bluetooth and that's about it.
400 mHz CPU
Off Road GPS
Comes with a DVD map disk. It's a hard drive system but the DVD loads the software and maps.
Are there any buyer incentives planned for February?
Try the Volkswagen Touareg Lease Questions discussion for money factor help.
A new iPod/USB adaptor is coming out this summer. Will fully integrate the ipod and treat it as an iPod not a CD changer.
No word yet on bluetooth but it will require you to take apart the speedo, tach controls and require you to route a can bus cable. You plug that in and you get MFD support. Also that unit requires VAG-com now VCDS programming. Hope this helps.
I was going to get a 08 Touareg, but didn't mainly because of the audio system (6 disc changer in the back are you kidding me). The only question is if I haven't bought a car when the 09 comes out....
Module: P/N 5N0 035 341
iPod cable: P/N 4F0 051 510 E
USB cable: P/N 5N0 035 558
Part numbers for the MDI and cables. For those with factory nav then some backup camera work will be needed. Also the Sirius antenna will need to be re routed since the RNS-510 has it's own sirius tuner. Also if you have Dynaudio then it will need programming. There is also a can bus adaptor for older models. If you have a touareg 2 then it will work without a can bus adaptor. Some VAG-Com now VCDS if it has a dsp sound system. Hope this helps.
The new and improved MDI aka Media Interface. It's the USB iPod unit that everybody is talking about. It also has full RNS-510 integration and other radio support. The RNS-510 again is the new touch screen navigation system for 09. It also supports Aux in and USB. For tech package owners you should be able to use this to replace the aux in as well. The USB port supports thumb drives. The iPod cable for this thing is sold seperately. The Unit could mount below the armrest. The iPod integration should actually behave like one. It will be much better than the current one. Won't officially come out until may. It requires a harness but thats fine. The harness will allow the song info to show up on the MFI. Hope this helps.
The 09 Touareg might finally get bluetooth as an option. The RNS-510 for the USA has a bluetooth audio menu. That means they are working on a module just for that version of the RNS-510
Hope this helps.
Diesel should make 221 hp. Mileage is probably better than the v10 monster. No mileage figures yet. Torque should be at around 404 lbs-ft.
One more thing is that the diesel should come out in January 09. The option packages are again identical to the VR6 model. A $3500 premium over the VR6 model so ok but could be priced better. Must be that Urea and US emission system.
Hope this helps again.
1. The trip computer shows my MPG about 6MPG more then I actually get. It shows about 30 to 32 on the highway and 26 to 28 overall. Hopefully that is only a fuel flow sensor, as we say for a computer, garbage in garbage out.
2. It pulls slightly to the right.
3. The rear body is about 1" lower at the left then on the right, I hope that maybe a minor sensor adjustment of the air suspension.
Other then that I love the car, the comfort and performance.
