I can certainly identify with what your saying. Point well taken that VW uses cheap parts......which is why they can offer attractive lease rates that seem almost too good to be true. They do a great job of making the car look good, but I would definitley say that having an extended warranty is a safe investment with these cars. In my case, both of my VW's (a 2002 Jetta GLS & 2003 GTI) were purchased from owners that abused these cars and thus needed work when I bought them. However, since having the work done I have had no other problems with either car (I will keep my fingers crossed!). I have been in the automotive repair business over 20 years and what I have been seeing is not good for the consumer. Government squeezing car manufacturers to build cleaner burning & more fuel efficient cars/trucks, which means end costs to consumers will rise accordingly. The reactionary response from the manufacturers will inevitably be cheaper materials being used and car manufacturers denying more and more legitimate warranty claims by consumers. I litigated a 2100.00 repair bill to replace the motor in my 2003 GTI and I am waiting for the decision in the mail to see if judgment was for or against me. In my opinion what I think we as consumers can expect is for warranty claims to be denied more frequently as car manufacturers try to minimize their losses. Large, heavily funded car manufacturers squaring off with consumers in court......you can do the math.
have changed plugs, fuel filter, new distrib cap and rotor, fuel additive added, , but very randomly the car will start to misfire.normally when first driven it is fine but after it has stopped and restarted how ever long after then it starts to misfire.
any ideas of what i should try next
If I shut her off then start her up again she will run like crap till I get through the gears and she blows black smoke like there is no tomorrow. Also does it if I mat her to full throttle.
I have changed plugs, wires, cap, button, distributor, air filter, fuel filter, and had it put back in time, also had the plunger on the cis system adjusted.
I've gone thought 3 sets of plugs in the last week cause they keep getting carbon build up on them.
Time to put her out to pasture...
Sounds like she had a good run, almost 25 years.
add the less expensive gas? I imagine it might hurt the engine?
Did you ever figure out what the problem was??
Have you taken your car in to have the OBD-II codes read?
