Lincoln Navigator Heating Ventilation Air Conditioning
I just purchased an 03 Gator with 60,000 miles. Just noticed that fan blows intermittent when in vent or AC mode. It will be blowing, then stop for a couple of seconds, then blow again for a minute or so, and continue repeating this pattern. It does this at all fan speeds.
Went by the local dealer, and they told me this was normal. When the engine fan turns on it will cause the inside fan to slow or stop, due to the way this system is set up. The rear air does not exhibit this same behavior, it will run constantly with no variable or intermittent blowing.
Anyone have an idea what is causing this or if this is normal?
Now I notice that when I turn on the heater it blows hot air most of the time. Sometimes it blows out cold air. I have no leaks and the temp gauge stays in the middle range. The coolant is full.
Was I supposed to bleed the cooling system? If so how do I do that with this truck. I did not see any bleed valves near the thermostat housing.
CAN SOMEONE PLEASE HELP!!!!
SUVs and Smart Shopper
:sick:
Check for a vacuum leak in the engien compartement where it connects to the engine and vacuum storage tank. Usually a vacuum tree on the fire wall.
Also, check to see if vacuum harness fits tight to control head in dash.
report back
gerry
The defrost ducts are not running either. Nothing in the front is blowing anything. I checked the fuses to see if anything was blown and had no luck. Could the blower motor be bad or have quit working.
