Buick Enclave Smells
Has anyone who owns an Enclave noticed a smell given off by the ventilation system when stopped? I took it to the dealer but they said it was 'normal' and would go away. Just wondering if anyone else had noticed this as I am not convinced it is 'normal'. Currently our Enclave only has 350 miles on it.
If that's what's happening here, the smell should fade away in a month or so.
I've owned a few new cars and never had one emit a smell before, so I'm just a little skeptical that it nothing. I'll give it a month and see.
Thanks again.
Maybe you could describe the smell a bit more - from what I'm reading through the lines, it sounds more like an oil/fluid smell instead of the interior plastics outgassing or some electrical smell.
And is it stronger running the vent fan or A/C or defrost mode?
It had the usual vanilla smell of the new car spray but after a few days that went away and we had this chemical smell, would give you a headache.
Took it to the dealer and they said it was the rear AC evaporator, I believe there is a service bulletin on it.
They cleaned and washed it and treated it but we didn't feel it helped.
I then took a 10 quart pail of water and put a cup of bleach in it (my neighbor is a mechanic and suggested this) and poured it into the cowl vents just below the windshield behind the hood on the Outside of the car. Rain goes in there anyway. This flushes the front evaporator and kills mold. It seemed to help some.
I alos purchase a spray that GM sells that removes odors, like Fabreese
This help quite a bit. I installed a cabin air filter behind the glove box. They don't come with one but it is available. Didn't help.
My wife thought the windshield wiper smelled like chemical. I had to agree. just the right one. Replaced it. helped some. It definately smelled.
Finally we went back to the dealer Walser Chrysler in Hopkins MN. The GM agreed to Ozone treat the car. This involves keeping the car overnight, putting an Ozone generator in the car for several hours.
The next day there was a slight Ozone smell which went away a day later and it hasn't smelled since, a year later. They didn't charge us for the treatment which I believe is about $200.
So try the Ozone treatment is what I would say, Have no idea of the cause.
