Chevrolet Blazer Emissions Control System Problems
Im 16 and this is my first car, today driving the check engine soon light came on, it didnt come on to school, but it came on, on the way home. It gave me the code P0452, which it says is a emissions control system low pressure sensor. What could this be? Is it something i can buy and fix myself or do i have to take it to te dealer? How long can this go?
Next, disconnect your battery for about 10-15 minutes and reconnect. This will reset the trouble codes stored in the computer.
As a friendly suggestion, when you post list the year model and mileage on your car. Makes it easier for the nice folks on this board to help you.
I have a 1989 S10blazer The 4.2 V6 fi 175,456 mileas. Went for emissions test and Air inj sys, egr,pcv,fuel inlet restrictor, Cat Coverter,Evap control sys, gas cap integrity all passed, tail pipe #'s
CO%
Idle limit 1.20 reading 7.22 fail
2500 rpm 1.20 reading 6.86 fail
HC ppm
Idle 220 ...382. fail
2500 rpm 220... 267 fail
Seems there is to much emisions coming out of tail pipe all other things are ok. I do smell fuel when it starts though, and iot runs rough sometimes. I always kept up on tunups. also seems to eat more gas.. Need to know what parts would effect emissions that would cause high CO%. need to know something before having it fixed. thanks
added OBD code
I did th OBD I code flashes 44 lean mixture. if that helps any
thANks again
Bosch O2 sensors are something like $20 from O' Reilly's (The local franchise parts house) or about $45 for a Delphi.
