Ford F-Series Radiator and Cooling Questions
I have a 03 6.0 Diesel. My problem is Im losing anti freeze. There is always some around the cap on the plastic cap. I tried a new cap still leaking. Seems under higher RPMS it blows out. Also latly I have noticed under idling heater blows cooler air until rpms are rasied. Any ideas for me.
As for the leak, borrow or buy a cooling system pressure check tool at autozone. Verify it is not leaking through the seam or other part of the radiator. If the cap is the only explanation for the leak and it has been replaced. My guess would be a disfigured mouth inlet on the radiator or radiator flow bottle depending what type of system you have.
As for your heater blowing cool air until high rpms; most likely causes are;
Heater control vavle problem, restricted flow or something. If it is a vaccum opperated heater control valve, make sure there isn't a damaged vaccum line that opperates the valve. You can try and temporarely bypass the vavle with a sutible tube or flushing tee and if you now always have heat, there is definitely a problem with the valve, coolant flow, or what activates the valve.
Another, not so common problem is a mix flow door that is vaccum opperated under your dash is malfunctioning.
Remember increasing the rpm increases coolant flow, and the ability of the engine to supply vaccum. Good luck.
I have a new one now that was under warranty but it would be nice to figure why the right side seals are going bad.
Any sugestion.
My cousin owns a 1997 F150 with the 4.6 V8. The system will build up pressure, get hot, and blow water out of the fill cap. He has no heat.He has backflushed the heater core and entire system. He's stumped please help
I had a leak in my heater core, put stop leak in and the steamed up windows stopped but I still have some residual smell. This is the second time I have had such a problem, the first time I took it in and they did a pressure check and found nothing... I had them change the anti-freeze anyway and had no problem for 2 years... now this... '97 F150 with 4.6
