BMW 3-Series Lighting
berenzweig
Member Posts: 1
I just got my new 2008 328i sedan last week. Needless to say, I love the car. I was wondering about the headlamps. I am interested in driving with only the two front "ring" lights on. I've seen other BMW owners drive like this, buy my vehicle doesn't have that option. The lighting options I have are as follows:
1) Xenon headlights which have the "ring" lights illuminated
2) Just the normal day time running lights with no Xenon and no "ring" lights
3) Daytime running lights with "ring" lights illuminated
4) Xenon only
The closest option I have to driving with only the "ring" lights on is option 3. I'm wondering if there is any way to get it where only the "ring" lights are on while I drive during the day?
Can anyone advise here? THANKS!
4) Xenon only
Hope it helps.
- I am unaware of any way of adding a Cassette player to any BMW in recent memory short of replacing the head unit. Unfortunately, replacing of the head unit will mean that you'll most likely lose the functionality of the steering wheel controls. As a fallback, you might want to consider buying something like an old Sony Walkman (FWIW, I actually still have a mint condition 1st Gen blue Walkman), and then connect it up via the Aux port.
- While your dealer was correct in that the 328i cannot be ordered with GFTs, he was bold face lying to you about using GFTs on the factory wheels. Plain and simple, the wheels that come on a 328i (regardless of package) CAN be used with conventional tires, period, full stop, the end. How? There is zero difference between the bead of a GFT and an RFT, and as such, other than the TPMS sensor (which works with ALL tires regardless of construction), there is no difference between the wheels that BMW puts on their cars today and the ones they put on their cars ten years ago. If you want to mess with your dealer a bit, ask him or her to show you in writing any statement by BMW regarding any incompatibilities between the factory wheels and GFTs.
Best Regards,
Shipo
One other thing to consider is the cost of replacement. A regular halogen bulb is less than $10 each. My dealer tells me that xenons installed are about $150 each. Oh yea, don't forget about the ignighters on each side that also periodically need replacement. These apparently cost about $200(?) per side.
Personally, unless you have poor night vision I would save the $800 cost of this option. On paper it sounds great but in reality is only modestly better than BMW's good standard halogen lamps.
Idoc
Here's the TSB for the infamous problems with the BMW 3 Series rear lighting:
http://www.bmwtis.com/tsb/bulletins/bulletin_graphic_temp/B630306g.htm
or
Despite problems with so many cars under warranty, BMW isn't pushing for a recall, prefering instead to allow their stealers to charge upwards of $400 to rewire the rear light connectors. Unfortunately, that's illegal as the lighting system is required by law, and when they fail in large numbers (which they have) they're supposed to initiate a recall. Looks like someone at BMW wasn't paying attention in their Ethics and Morals class . . .
In the meanwhile, please help by giving a short summary of your E46 lighting problem here:
Safercar.gov
You can also report a vehicle safety issue to NHTSA online at our vehicle safety Web site: www.safercar.gov. Select “File a Complaint” within the Defects and Recalls section of the home page. The information you submit via the Web site is recorded in VOQ format, entered into our consumer complaint database, and provided to our technical staff for evaluation.
When you fill out a VOQ online, you will be given the option of checking a box to authorize or not authorize the release of your personal identifiers to the manufacturer of the alleged defective product you own. Again, while you are not required to provide such authorization, doing so can sometimes help facilitate the recall process.
U.S. Mail
To report a safety complaint to NHTSA by mail, send your letter to:
U.S. Department of Transportation
National Highway Traffic Safety Administration
Office of Defects Investigation (NVS-210)
1200 New Jersey Avenue SE
Washington, DC 20590
A written letter is probably best. Write the words "Petition for formal investigation" in your letter and include any receipts you may have.
