Dodge Ram Audio/Stereo Problems
creaser113
Member Posts: 2
I have a 2002 Ram 1500 and my battery has been weakened and/or is dead in the mornings or over period of time of not driving it. I have the factory Infinity Sound System and since I've removed the fuse for the "radio amp" it has not weakened or gone dead, narrowing the problem down to the radio and/or the infinity sound system. Any suggestion of what might be causing this problem? Thanks!
See Also
How To Find A Short In Your Car
See Also
Does anyone know the actual size and shape of the speaker, and does the entire door panel have to be removed to replace it???
Yes, the molded grille is round, but, knowing American car makers, the speaker behind it does not have to be round...
I would like to order replacement speakers (both doors) in advance, so I can change them at my leisure...
kcram - Pickups Host
thanks, Karl
kcram - Pickups/Wagons Host
Hey, I'm just a simpleminded lawyer, I don't know nuthin' about
birthin' no babiesworking these super duper computer radio CD palyers...Sorry, I fell into my "Gone with the Wind" mode... :P
I tried your suggestion of reaching under the large fuse/breaker box under the hood and moving the wires around. I also tried tapping on the fuses and breakers. I even removed and cleaned the ends of all the fuses and breakers but I still do not have the front speakers working. Can you be any more specific as to where the problem may exist? Also what did you mean when you wrote "rod bumps turn my speakers off and on"? Daniel
If the entire unit had a short, or bad ground, would the CD player also not work, so I localize it from the back of the radio to the antenna...
1. I just got the truck. The steering wheel controls for the radio do not work. The person who had it before me had an after market radio in it and now it has the stock radio. Does anyone no why it does not work?
2. I have HID headlights in it they are of high quality. When I turn them on I get static through the radio. If I were to run another ground from the radio would that fix the problem. Or is there some other way I can fix this problem?
Anyone know what the problem might be?
