Toyota RAV4 Leaks
I drive a 2002 Toyota Rav4 and my recent problem is that I have a leak that in the front passenger's side floor area. Prior to that I didn't have the windshield replace or had a collsion. I did change a new battery which is located in the front passenger's side. The leak seem to occured through the side wall of the passenger's side. The leak seem to start after the new battery was installed. My question is that normal for 2002 Rav4 or did I forget a procedure when removing and installing the battery. I found out the leak when there was rain for three straight days.
Any help with this would be greatly appreciated. Thanks!!!!!!!!!:)
We have also recently developed a leak in the rear cargo area as well. We have taken all the carpet out of the car as well as all of the sidewell liners. The water is coming out from the roof area and running down the headliner, coming out around the seal of the left rear passenger door window area and draining into the cargo compartment. We are currently investigating the exact cause of this leak and will update you when we have determined how to fix it.
As for the rear cargo area, I have not yet had that problem but would appreciate hearing your solution as it is probably another drainage design flaw on the RAV4 that might occur with mine, in time.
I am currently experiencing the same problem, in my drivers side nearly under my seat. Is this the cargo space? I have sat in my car in the rain to see where it might be coming from, but no answer yet.
Do any of you have any other suggestions? as its really starting to smell and Im concerned it will be causing rust.
If you don't have a sun/moon roof, it probably is still a drainage problem from your roof, windshield area, see above postings, as I learned that runoff drains, when operating properly underneath the drivers and passenger floor. So, look as suggested for remote drainage problem.
SUVs and Smart Shopper
There are drainholes in the body of the car on the front side of the sunroof on both the driver's and passenger's side. Who knew? Apparently, they drain through tubes, then out between the front door and the mud flap. These become clogged with dirt, leaves and debris. I park under an oak tree, so I get acorns and all sorts of matter.
The forum described it like this: Open the sunroof. Get in the back seat and stick your head out. Look to the front of where the sunroof closes on the indentation in the roof. To the right and left IN THE BODY ITSELF, there are 2 holes. Near the corners. I actually could not see the one on the driver's side because it was completely clogged with mud and a leaf. The passenger's side was 1/2 clogged.
Apparently the area where they drain to (between the door and mudflap) also gets clogged. It is behind a plastic cover-type thing. Mine was full. I just used a screwdriver or something to hold it open a little and used needlenose pliers to get out all the debris (or at least some of it - there was alot).
Don't know if it worked yet, but I am guessing opening up the drain holes can't hurt. Oh, someone else suggested blowing it out with a compressor.
Also,since the rubber grommet cover is not permanently bonded or glued to the metal mounting plate, tightening the fastener causes the grommet to pull away compromising the seal. So, to solve the problem I removed the switch assembly and the rubber grommet. Washed,cleaned and dried the switch plate,rubber grommet,and the mounting area on the vehicle. I then applied urethane windshield sealant around the body holes (One for the bolt and the other for the switch pass through). Then applied a small bead of sealant around the outside edge of the reassembled unit. Next, I positioned the assembly and inserted the retaining bolt with just enough force to cause the sealant to ooze from around the entire assembly. Cleaned off the excess sealant for appearance and water tested. Consequently,no more leaks. The following is a list of tips that may help if you have a similar leak problem and quite possibly might be applicable to other models that use the same type of door switch.
1. The previous owner and her dealer could not find the leak !
2. In most cases you are unable to duplicate a leak with a water hose,however when it rains it will show up every time.
3. When searching for a leak with a water hose,start at the bottom of the vehicle and slowly work your way up. It's common to assume that the leak is always from the top.
4. Examination of the switch assembly did not yield an apparent problem but water testing did.
5. Silicone Rtv sealant would probably work in place of urethane windshield sealant.
6. In the case of this 2008 Rav4 the water dripped from the left rear cargo tie d-ring located near the floor area.
7. Do not excessively tighten the retaining bolt else all the sealant will squeeze out compromising the seal. You can always tighten a little more after the sealant sets if you feel the need.
8.Also put a small amount of sealant around the bolt head before installing same.
Hope this helps
The second leak came from 4 screw holes in the troughs on the roof that are intended for roof rack braces. My problem is that my rav has 6 sets of two holes in the trough and my roof rack had only 4 mounts leaving 4 holes wide open that allowed rain water to run down the inside of the plastic interior panels and gather in the front floor boards.
I had to remove carpet, the ceiling panel and the interior panels to discover this. Hopefully this information will help you locate possible leaks in your Rav
Right now my carpet is out. all the seats are out. the interior panels are out and we are "de-molding" the interior. What a project!
It gets dry with age and allow water to come in when you drive through rain it took me 3 hours to find this . No leak was ciming from above
Check the picture , i have a rav 4
I directed water from a hose and I could see the water coming . Hope this help
Get this washer change if you find the code number for that piece .
Hope this help
