Pontiac Sunfire Warning Lights and Problem Codes
My 1996 Sunfire convertible's (2.4L-manual) check oil light stayed on after starting even though the oil level was fine. Turning the car off and restarting always turned the light off. After a year or so I got use to it. Then one day, the car would not accelerate quickly without a jerking motion. One ignition coil and four new spark plugs later and both problems have been fixed.
This seems to be a fairly common problem amongst my friends so I thought I'd share the solution here.
Right after my first fill-up since my ignition coil was replaced.
Good Luck let me know what happens!
Brittani
Paul
Brittani
Guess I was too gentle of a driver.
Can someone give me a few pointers on what I can check before I have to go into a shop?
