Chevy Silverado and GMC Sierra Exhaust System Questions
I own a 2000 chev silverado 2500 with a 6.0 litre. I recently had dual exhaust installed on it (they sound sweet by the way). Before it was installed, i wanted them look at an exhaust leak i could hear near the engine compartment. Which i thought was the collector gasket. With out even looking the guy said "its probably the exhaust manifold bolts." Sure enough, looked under the hood and the front and the rear bolts were broke off on the drivers side. He said he's ran into that alot and that they break flush with the head so you have to remove the head because there's not enough clearance between the head and the firewall.
Has anyone else had this problem?
I've heard it happens on the 5.3 liters too.
would adding a volant cai void the warranty? not impress w/the 14,4 gal i been averaging...w/only 3 tanks of gas and around 1000 miles on it sofar....tranny seems funky..but hoping its still breakin in...thanks in advance
i also want to remove the front bumper license plate holder as i dont need it in okla. Isn't the plate holder molded as part of the bumper?
tranny seems funky
Yeah GM hasn't gotten the programming right on the 6 sp auto.
curious what that muffler looking thing is at the passenger rear tire
If it's smaller than the muffler it's probably a resonator and will be removed if installing a catback which again doesn't do much except increase incab noise.
Course if you're concerned about passing emission testing well you can forget that.
ANYONE ELSE HAVING THIS NOISE PROBLEM? ITS SO LOUD WHEN I GO BY SOMEONE THEY LOOK AT ME AND GO????????
Just recently (starting last month) .. when I park truck in garage (its shut off) ... after 10 minutes... I would hear a BANG noise - consistantly each evening .. I was not sure what it was .. so I stayed under truck each night .. and sure enough - after approx 10 minutes .. I would hear a single BANG - pretty loud.
After monitoring this .. I notice the bang is coming from muffler.
So I hear a single loud BANG after my truck(turned off) sits for 10 minutes.
Any ideas ? The truck runs and sounds fine .. just a BANG after truck sits for 10 minutes .. this is consistant behavior.
I am hoping someone has seen this before ?
Truck is almost 6 years old - 25K miles - original exhaust.
I bought it new and had a flowmaster dual exhaust system installed on it when i first got it. Every since I had it installed, the engine kinda stutters, i guess you could say, but it is more noticeable when you around 50 mph or so, and when you get over 60 mph the engine will clear up and run smooth.
Has anyone else had this problem? I would appreciate some help. Thanks!
A Borla or Corsa system designed for the Silverado would deliver a little better performance.
I understand that there will be a smog check required here for my '07.5 LMM starting next year.
The previous owner went to an aftermarket exhaust from the DPF back that wont affect the test. There are folks at the dieselplace.com site who have done and reported on multiple combinations of exhaust mods for the various Duramax generations.
I am inclined to believe that it is an aesthetic thing 'cause I REALLY don't see ever reaching the break-even point on the ROI. I think it would be a LOT more miles than I will put on it. Even considering that I will be pulling a trailer most of them.
Yes, I like the exhaust sound but would not consider spending for the conversion. Also, I have no idea what the original exhaust sounded like.
:confuse: :confuse: :confuse: :confuse:
Best,
Sarah
GM Customer Service
We'd be happy to look into this further and move towards a resolution. Please email us at socialmedia@gm.com with the following information so we can get a case started: your name and Edmunds username, phone and address, the last 8 digits of your VIN and current mileage, and the name of your involved dealership.
All the best -
Sarah, GM Customer Service
