Leaking Coolant on '02 Impala 140,000 miles
in Chevrolet
There seems to be a leak in my coolant, but only when the car is turned on, any suggestions on what the problem could be?
I've came up with either a leak in one of the lines or the head gasket.
My 3.4L van just had the water pump replaced couple weeks ago. The coolant sprayed out on the side near water pump.
If you hear squealing sound (coolant on the belt) when first started the car, then it is indicative of water pump leaking. Water pump fix is cheaper than the gasket replacement (intake gasket for the notorious 3.4L V6, especially on GM minivan: virtually every van has this gasket problem).
jt
On high mileage vehicle, water pump seal would break down and cause the coolant leak out from weep hole (purposely design to show this problem). If that is the case, the auto shop would be able to determine that by looking at the weep hole for any water residue (small leak)
Before you sink $200 for the water pump replacement, at least check the following things on your own:
1. The cap on the coolant recovering plastic reservoir : is this close?
2. The radiator cap: Is this locked properly. It has marking on it telling user the locking position.
The coolant leak could be caused by :
1. Hose crack (low cost)
2. Radiator leak (moderate cost)
3. Water pump leak (moderate cost)
4. Intake manifold leak (most costly)
5. Radiator cap leak (low cost)
6. Other?
jt
Thanks, O. M.
http://www.dexcoolsettlement.com/
My properly serviced Impala is at 160,000 miles and running strong......resisting trading for an 08 LTZ.
