95 Civic - Fix or Sell As Is?
                    I have a 1995 Honda Civic LX with 106K miles in very good condition, never had a problem with it. I now use public transportation to commute to work and hardly ever use the car so I'm looking to sell it. This morning the mechanic told me it needs new front brake pads, a new radiator, a new oil pan gasket, a tune up, and a new timing belt at 120K. All of this work will restore it tip-top shape. I'm interested to hear what I should have fixed before I sell the car. Thanks!
- radiator leaking or clogged, requireing a replacement
- front pads squealing or grinding or pulsating, requireing replacement?
- oil leaking from your engine, requireing gasket replacement?
- engine running rough, hesitating, poor mileage....noticeable to a buyer?
- timing belt is known maintenance
Unless that stuff is absolutely needed to fix a problem to sell, you will probably not get that much more for the 13 yr old vehicle.
Where are you located?
I have a rear end rattle and maybe a cv bad.
How much to fix a cv?
Any know issues with that rattle when it rolls, faster rattle as speed increases?
And at this age, I would recommend draining out the coolant, replacing the coolant hoses and clamps and then refilling it with new coolant. Another thing to check is when the last time the timing belt was replaced. They also replace the water pump when they do that. If the belt snaps, bye bye engine. It's not fun! Try this.. you'd have to repair the entire engine, not good! So definitely find that out!
Hope that helps.
