Fuel Line/filter froze?? 04 Grand Am
I have a 2004 grand am and let it set outside 20 degrees below, i assume fuel is froze up, before this a week ago went to another town and died a couple of times,i get it service when supposed to. I dont know if they put new fuel filter on when they service or not, i am assuming not. I checked that valve on the fuel rail { lines } by the motor with the car off and pushed the needle in and just a little gas came out and quit, should all the gas in the line come out with the pressure or will it only keep coming out if i have the key on and the fuel pump running, i was just thinking more should of come out than did even with key off, only got about a thimble full. Can i check that with the key on and fuel pump running, it should keep squirting out if the lines aint froze, is this correct !! And i did put heat in the gas tan a couple of fills ago !! Any ideas !! Thanks
I was told the catalitc converter was plugged , but when i went to the muffler place I was told that my Ignition coil pack was toast. They replaced it and it runs great now but now i have to replace the O2 sensor. I hope this might help.
