Gated Shifters (Automatic Transmissions)
mikevegas06
Member Posts: 272
I've noticed for some time now, that a good number of automobile manufactures use an overly complex path for the gear selector (IMO). I much prefer the mundane looking but highly useful verticle path. Or the "h-path"/ "inverted h-path" for transmissions with the the manual shift mode. What do you think?
pic1
pic2
Since automatics transmissions are entirely controlled by computers these days, and the shifter itself does anything any longer but move a solenoid to give the compouter instructions, I can't figure why we haven't gone to push-button automatics by now anyway. The automatic shifter is a relic from the past.
pic2
Maybe, lol.
Finally, click the button for the pics
gear shift button
You just struck a nerve with KC on that one:
What's that THING in the middle of my truck?
Hurts my right knee just looking at it.
My best friend's Denali and my Tahoe have the shifter on a stalk and it works fine for me. But Like Nippon said a button or paddle would work as well. Without that shifter on the floor you would have more room for storage in that picture.
I don't live in the flatlands and I often shift the Steptronic in my Fiver when descending the hills in my area or driving twisty roads. The console shifter is well set-up for this type of shifting. You don't have to look at it and you can do it all by feel, much as you would a manual.
OTOH, you can't imagine the frustration I feel when driving my MIL's Buick in hilly country, with it's sloppy column shifted three-speed it is nearly impossible to make
a clean shift into 2nd, in fact it is difficult to select Reverse even though it's right next to Park.
Funny thing is both A/Ts are MY 2000, made by GM (which builds gearboxes for BMW in Strasbourg, France.
If I have to drive an autobox give me a good console mounted shifter and/or paddles.
My bad, then. It's still got a sucky shift pattern (if you could call it that) :lemon: .
PRNOD21
There's a circle around the D, but no seperate D (without a circle), the car goes into overdrive very early so you get no pickup driving around town but not great mileage (you're lucky to break 20). Highway mileage can be very good, I've hit 30 on a trip.
My BMW does around 24C/29H and has plenty of power whenever you ring for it.
LeSabre Custom.
Edmunds only went back to 1990, but the 1990 LeSabre had a 4 speed
http://www.edmunds.com/used/1990/buick/lesabre/568/standard.html
The 2000 LeSabre definitely had a 4 speed
http://www.edmunds.com/used/2000/buick/lesabre/8795/standard.html
PRNOD21
p.s. It was a nice car back in 1989 - I remember it would get almost 30mpg on the highway...
With a gated shifter, you simply move it into the gears - a one-step process. With a column shifter, you have to press the release button first then move it into the gears - a two-step process.
Not to mention that a properly designed gated shifter looks much better than a column one.
The column shifters in all new Acuras and Infinitis aren't bad at all but a gated one is better.
I think possibly the complainers have never encountered a properly designed "gated" shifter. Personally I have yet to meet the column shifter that I liked.
That being said I prefer the classic floor shift with the straight line down. You can switch gears really quickly. I'm not really a fan of the gated shifters, they seem to overcomplicate the process.
The Escape I drive now has the floor shfter and has a fairly simple setup and I like it.
I do not like being in an overdrive gear in hilly country, to get decent power going up
and braking going down you need to be in 2nd or 3rd gear. Either is tricky to select from the column although I admit going back into D is easy because the detents are set up properly so that it'll drop right into it.
On a more positive note, I think those of you complaining about gated shifter patterns being overly complex would be surprised to know that the motion to go from 5th to 4th on my car's Steptronic is almost the same that you'd use to go from 5th to 4th w a manual shift (in a typical 5-sp pattern).
Move Lever back, then to left and back again. Tap lever back once for Fourth, twice for third.
If that's too complex, there's always the "shifter" in the new Jag XF>
:P
Ha, I knew someone would do it sooner or later. I would have stuck the rotary knob on the dashboard, though.
(And that's before I even mention how the Tribute/Escape's column shifter blocked all the radio controls when it was in drive)
What, are you kidding me?
Gated shifter - move the stick into gears (1-step process)
Straight line shifter - press the release button then move the stick into gears (2-step process)
A 1-step process is "overly complicated" than a 2-step process? :confuse:
Ultimately, I think it became an issue of "imitation being the sincerest form of flattery" that other manufacturers started to offer this. Lexus and Infiniti both did this on their early cars in the '90's.
Now, with the manu-matics being all the rage, there are probably less gated shifters - everybody has the extra slot for the + / - for up and down shifts (my wife's '08 VUE has this on the 6-speed auto).
:confuse:
My Lexus has the gated shifter with the manumatic tranny.
I might have this a little off, but in my column shift auto fintail (I think fintails might have been the last column shift automatic MB) to put it into drive from park, you pull the lever towards you, then down, then back a little, then down a little more and it hits the drive notch...or something to that effect. Next time I drive it I will try to remember exactly how it works. People who have never drove one are always thrown off when they try to get going.
