Toyota Solara 2008
I am going to buy a 2008 Solara Convertible SLE. I want to know where I can go to find some aftermarket performance items. I ordered it with 18" TRD rims, lowering springs, strut brace and exhaust. I am looking for a cold air intake, slotted brake kits, and a billet grille...
I have tried ALL the obvious internet searches and it seems that no one is producing goodies in the after market....YET
Any ideas?
Any ideas?
I have a 2000 Solar SLE V6 Coupe which has 106,000 miles and runs great and I have had no issues. Every one tells me the car will be good for at least another 100,000 miles. I would have kept the car longer but because they are discountinuing the Solara I thought I would by a new one. After reading all the post, I am having second thoughts. It sounds like Toyota's quality is not what it used to be. Has quality really suffered? Do you think it wiser to keep the 2000 (which runs great) and just run it into the ground. Any thoughts would be helpful.
I hope this helps you out...good luck
PS...the Solara is being suspended, not discontinued. There will be a one year interruption in production and then in 2010 a brand new version will come out.
*(I hadn't heard the 'only suspended' rumor before. I hope that is true. Anybody have a source for this comment?)
What ever it was, it was not your fault.
I had a 2002 Solara coupe and all I replaced was a tail light bulb.
Is your car a convertible?? Leaks on those have been a problem.
Joe
I did some checking and I found some early years Solara did have some steering gasket leaks, but mostly in cars with higher mileage then yours. Don't worry the problem is quite rare, there are many Solaras on the road with over 200,000 miles and little or no problems. My car is getting 31 mpg on my trip to work and 41 on long trips, with the price of gas you have a winner.
Joe
The Solaras are ceasing production I believe in August, so 2008 is the last model year for the line (stinks!).
:shades: Check out the insideline article: :shades:
http://www.edmunds.com/insideline/do/News/articleId=130608
Cheers!!
--njexpress
Frank
I took it to my local Toyota dealer (St. Charles, IL), they ran some tests that Toyota says they should run in such cases and said all checked out fine so there's nothing more they can do. They also stated the following conclusion on my receipt. "Cause: Subzero temperatures are causing temp sensor to remain at subfreezing value". When I reminded them that the problem occurred in warm temperatures, they stuck to their guns insisting that this is what their mechanic found. I was (and still am) furious. Next I called the Toyota Customer Assistance Center (800-331-4331) and opened a case. A case mgr. called back and listened sympathetically but said there was nothing they could do if the dealer couldn't find a problem. This is the 5th Toyota my wife and I have owned (she drives an '07 RAV4) but it will be our last if Toyota won't fix our problems under warranty - and that's what I told both the dealer and corporate.
If you've seen the same problem, please let me know. Maybe I can get someone at Toyota to listen if the problem is bigger than just me.
there are other glitches so i haven't brought it to dealer yet but figured i'd ask if my experience is the norm (hard to believe) ---no,i did not test drive one---hell, had 3 camries in family---so what's to test---expected a slightly jittery sedan not a hip hop front end---will be grateful for any info/ideas/opinions/experiences,etc---
thanks---
ps---mileage is 4200plus and had problem from day one---
TSB Number:TSB-0106-08 NHTSA Number:10025856 TSB Date:June 11, 2008 Date Added to File:September 10, 2008
Failing Component:
Suspension:Front
Summary:
Toyota: front suspension- some 2007-2008 model year avalon, camry, camry hv, and solara vehicles may exhibit a steering wheel flutter and/or a body vibration (floor or seats) at highway speeds (approx. 65-75 mph [105-121 km/h]).
1. The temp gauge will only change after you have been driving over 16 mph for 200 seconds, and then only by 1 degree. If you drop below 16 mph then the 200 seconds time period is started all over again.
2. If the car has been off for over 1 hour the temp gauge will then report the temp at startup.
3. If the temp at startup after 1 hour is high because of engine heat affecting it, then the gauge will start going down more rapidly to match the actual outside air temp flowing over the sensor.
The service manager and I took a ride on the freeway for about 20 minutes when the reading was started at 76 and indeed the reading increased every 200 seconds by at least 1 degree and sometimes 2 degrees. It was at least 100 that day so for our entire ride the outside temp was still not being displayed correctly, ending up at around 88. The service manager then contacted Field Service again and got basically the same answer. The service manager called me the next day and his quote was "What a piece of poop", but he didn't use the word "poop". Toyota didn't use any programming algorithm that makes any sense and their own Field Service staff doesn't have any good answer. In other words Toyota's answer is "Pack it where the sun doesn't shine".
There seems to be other rules that apply here but I haven't figured all of them out yet.
I hope this helps others understand this issue. Good luck.
Help
The engine hesitation problem has been mentioned a few times in the Solara Forum (you can find their posts by typing "hesitation" into the search box at the top of the Toyota Solara Forumpage. About a week ago, one of our members mentioned that his hesitation disappeared after changing out the air filter: K&N Air Filter.
Also, the passenger seat does not bing if the passenger is not wearing a seat belt. Anyone know if this is normal. The book says it should bing. Thanks
My passenger seat DOES bing if the passenger is not wearing a seat belt. There is some kind of sensor built into the seat to detect whether or not there is a "human" there, so perhaps that sensor is faulty.
Thanks all!
Thanks again!
My Toyota dealer has the car. They have claimed they have never heard of this issue. But I see here there is a TSB as well as many posts. Has anyone else experienced what I am experiencing. If so, what was the fix? According to the TSB it is the front end suspension. Has anyone had this issue, had the suspension fixed and did it/not resolve the shaking/vibrating?
Would really like to figure this out. Can anyone help me?
i was directed to a service bulletin issued to toyota dealers which i have at home/am away for another week or so--
but if you scroll thru the messages here you may find the reference---if not go to click and clack and check their site----i may have been given info there---
but your problem sounds like it's something other than what i experience---have not taken car to dealer so no idea what dealers do/or don't---driving my '95 camry---better ride---
if you don't find the service bulletin reference let me know and i'll try to find it in my email/files,etc---
I have a 2008 Toyota Solara SLEv6 with 41k miles.
The passenger side low-beam HID bulb is not working properly.
I'm a DOYer by nature and would like to diagnose and fix the problem myself.
From the little I was able to find on the internet on this, I cannot tell if it's going to be easy or hard to access the bulb(s) and/or ballast(s) and/or relay(s).
So, before I knock myself out trying to fumble with this on my own, I thought I'd check to see if anyone out there in Edmunds-land has had any experience with any of this.
First, the symptoms: When I turn the headlamps (HID) on, the passenger side bulb turns on for just a few seconds, and then turns off. It seems that when it is on for those few seconds, the intensity is lower than it should be. I can flick the lights off, then on again, and the same thing happens. It'll light up for just a few seconds.
I've already verified that the FUSES are all good. Each bulb has it's own dedicated fuse.
From that information, I don't know if it's the bulb, the ballast, or the relay?
Here are the steps I'd LIKE to take:
1) Swap the passenger/driver bulbs. If the DS fails, then I need a new bulb. FINIS!
2) Swap the PS/DS relays. If the DS fails, then I need a new relay. FINIS!
3) Swap the PS/DS ballasts. If the DS fails, then I need a new ballast. FINIS!
If, after all of that, the DS continues to work, then I probably have a wiring or connection problem and I'll have to (gulp) resort to bringing it to an "expert" to fix.
But I'm still not sure how easy or hard it might be to access ANY of these items - bulb, ballast, relay. I would imagine the relay is easily accessible, so perhaps I should start with that item.
I was able to easily open the plastic cover over the bulb housing. But I didn't attempt anything else since I have not seen any diagrams or videos or description on how to remove/install the bulb.
Any experiences you'd like to share will be helpful.
I had someone more familiar with cars listen to the engine and he doesn't think a dry start is the problem, but couldn't identify what it might be.
Wondering if others have had this issue and might know what the problem is? The car has 45000 miles on it and has had all regularly scheduled maintenance.
Thank you for any suggestions!
I wanted to fill you in on the outcome.
I stopped at a Toyota dealership up in CT on a Friday when they weren't busy and asked them the cost of the bulb. It was $175. I asked what the installation price was and they said "Oh, no charge for that". I jumped on it! It took them about 20 minutes to get it in, but they did it and I drove away happy !
I recall when I asked my local dealerships in NJ they wanted something like $100-$125 to install it !
Problem with Daytime Running Lights (DRL)
I recently discovered that my DRL weren't working .I tried a LOT of things and finally arrived at the solution.
On the 2008 (and perhaps others) the DRL WILL BE DISABLED IF ANY OF YOUR HIGH_BEAM BULBS IS OUT. This morning I tested my high-beams (which you don't use all that frequently) and discovered one was out. I was very excited to learn of this. I thought that perhaps there might be a relationship to my DRL problem, and I was right. Interesting that with all of the searches I did on the internet, and all of the documentation I have on my vehicle, I was unable to find this important tidbit!
Good info, solaraman -- I wouldn't have thought to check the highbeams either! Still trying to figure out why the dealer installed that lowbeam bulb for free, though.
