Mitsubishi Outlander vs. Subaru Forester
While I’ve never said explicitly that “Outlander has 4 wheel torque vectoring”, I did not know at that time if there is a difference, since both cars have that Super-All Wheel Control system. So yes, I made an honest assumption.
However leaning more now, perhaps there is no mistake and there is less difference then you think. I have already written about this briefly:
Mitsu claims that Evo can adjust torque to any wheel at any time while Evo has only one active differential (rear). Then what happens with front axle? EVO employs “Sport ABS” system also used to be called at one time Active Braking system, which is capable to transfer torque side-to-side on all 4 wheels. In a white paper Mitsubishi also calls this system Lateral Braking Control .
Again this system functions in addition to the active rear differential.
Unlike a passive EDL which applies brakes to the wheel where it senses slippage, this is an active yaw control based torque distribution system where braking used to send torque to the outside wheel to improve cornering. Based on one online source however, this type of torque transfer might be limited to 50%, while an active diff can do 100% side-to-side transfer.
That would qualify for active torque transfer. That very system used by Mercedes S-Class: Torque Vectoring Brake, and by Porsche 911: Porsche Torque Vectoring. Except for these two guys that’s the only way: there is no active differential.
Like EVO, the Outlander GT also has active differential on one axle, but on front. If we browse throgh the Mitsubishi USA site, we won’t find much info what else is happening there: the description is very basic. However the Mitsubishi Australia site says that Outlander “applies braking force to that particular wheel and sends extra power and torque to other wheels”, which is in essence an Active Braking system employed by EVO.
>> Perhaps you believed that at the time, but we now know they're not the same.
Nothing is ever the same. But both EVO and GT have one active center diff and one active ‘axle’ diff. It seems the difference is mainly in active diff orientation: front or rear. Perhaps they did it for better weight distribution moving it to the front in order to move heavier center diff to the rear.
Agreed 100%, and by the way Subaru's web site is no different.
Plus it doesn't help that Subaru puts the same "Symmetrical AWD" label on at least 3 distinct AWD systems.
I can say that the system on our 09 Forester was very effective getting us around in the 20" snow/blizzard we just had. I can't tell when the traction/stability control kicks in were it not for the light on the dash telling me so. It keeps a straight course even with uneven traction (right wheels on shoulder's snow/ice to make room for oncoming trucks).
I guess all I really need to know is this - it works.
Once in a while we'll find a technical PDF file from the JDM cars and they're better at telling us what's actually happening than any marketing materials from SoA.
By the way, I did some research on the con rod bearing issue - it affected production of 2009 XT models built from 8-Jan-08 to 5-Apr-08, by April 8 all dealers stopped selling them, and the issue was resolved and sales resumed before the end of the month (April 23).
Serious problem, sure, but they handled it well, and quickly.
"SubbieNewbie" had the problem and got a new engine overnighted, plus a loaner, plus a 100k warranty on the new engine. Within 2 days he drove off. They replaced the entire longblock, not taking any chances.
to be continued...
See who drives them...90% chicks. However, the Forester is a great vehicle that is reliable..
VIN range for affected Foresters begins with 9*700001 and ends with 9*700139.
Consumer Reports dinged the 2009 Foreser, rightfully so. Even though that is a very small percentage of production, it's a serious problem and so it carried a lot more weight.
The 2010 models will show a big improvement simply because they were never affected in the first place.
I think they handled the problem very well. Especially SoA (America).
Would you trust MMNA do take care of you in the same manner is something happens to a Mitsubishi? That's a rhetorical question, no need to answer.
http://townhall-talk.edmunds.com/direct/view/.f16f885/9#MSG9
If your dealer isn't helping call 800-MITSU-2000 for MMNA. Is that covered by the powertrain warranty? I'm not sure.
I had a wheel bearing fail on a '95 Mazda 626, and from your description I think that's very likely the cause, especially if the whirring changes frequency with speed.
Best of luck.
Hopefully they bring back a manual/turbo combo, let's see.
Even if it turns out to be someting mechanical, I still have alot of miles left on the warranty.. I would think that the wheel bearing would be covered under the drive train 10/100,000...
So far, after 42,000 miles I have never had any problem with my Outlander. :surprise: I am quite impressed with the quality..
Having said that, I wouldn't drive around with an unresolved whirring noise.
Do you have a source for the gender percentages?
I ask because the whole segment is mostly female. The best seller (CR-V) is actually marketed as a "Toddler Mom" vehicle by Honda, and quite successfully.
Subaru did not provide an engine appropriate to function with high performance turbocharger. They simply attached turbocharger to a stock "boxer" engine. Irresponsible and cheap approach
Correction:
Did a little research and found that the Forester XT actually does use the upgraded connnecting rods from the STi. Part number is 12100AA180 for both.
What failed was the con rod bearings, not the upgraded con rods. They didn't throw a rod.
Note also that the turbo engines were affected but the normally aspirated Foresters were not, because they use a different Rod Assembly.
That is why no normally aspirated models were affected by this issue.
Just setting the record straight.
Block set 11008930
Cylinder Head L 11063AB330
Cylinder Head R 11039AB910
Piston Set 12006AC390
Piston Ring Set 12033AB340
Rod Assembly 12100AA180
Crankshaft 12200AA330
Exhaust Valve 13202AA570
Intake Valve 13201AA371
FXT:
Block set 11008930
Cylinder Head L 11063AB250
Cylinder Head R 11039AB820
Piston Set 12006AD210
So STI parts include the block set, piston ring set, connecting rod assembly, the crankshaft itself, and intake valves and exhaust valves. That's a lot of upgrades, if you ask me.
The heads are different, as are the pistons.
If we apply the KISS theory, perhaps the 220hp version of the engine (which I believe you have) makes more sense. Low compression, and designed to run on 87 octane.
Subaru's EZ30 engine (Outback, Tribeca) ran on recommended premium, but they squeezed 250hp out of it (a little less SAE hp). Thankfully the 3.6l V6 is now tuned for regular fuel, but you've gotta shop Outback to get it. That's still in the Outlander GT's price range, FWIW.
We didn't get the turbo, but keep in mind 224hp is a lot less than what an STi makes, so it's not high strung at all. Test drive one, the turbo is actually pretty mellow, it's geared taller and makes less exhaust noise (thanks to, yes, that Mitsu TD04 that's in the way of the exhaust path) than the normally aspirated engine.
I think if the F-XT had been available with a manual transmission, I would have pushed for it. A true manual with a clutch is more in character with a sporty model. Subaru just wasn't selling any of them, so they dropped it.
If you get the chance, go test drive an 04 F-XT manual. C&D hit 60mph in 5.4 seconds. It is just absurdly fast. I had to test drive it twice because I could not believe it.
I wonder if they will produce a Forester Sport XT, XTi, or STi. Part of me would like to see one, but the practical side of me knows it won't sell well. The STi is already a 5 door, and that's what most enthusiasts would pick anyway. Or a plain WRX.
We also own a high-strung boy-racer type vehicle (Miata) and a big V6 (Sienna) and each has its pros and cons. The Miata is what I want to drive, while the Sienna is what I have to drive.
Both get the job done.
Cheers.
Exactly! Power to tow and an easy vehicle to drive and good economy for the size. (almost as much power as our old Durango, but about twice the hwy mpgs) A great overall compromise in today's times with gas prices. I have no desire to spend the money for the Outlander GT and wouldn't have bought one in 2007 (if available) as I chose a LS vs the XLS back then (much less $ and had all I really needed.)
Believe it or not, I also own an older Lotus Esprit. Weighs about 2200 lbs. Its motor is fine for the light weight, but wouldn't want to power a CUV that way. (Lotus' philosophy of small displacement motors works fine in very light cars yielding great power to weight and mpgs too, but not for 2 ton vehicles) I also appreciate not rowing the gears in the Outlander (can't beat the 6 speed auto for that purpose) The Esprit is something you must maintain and is an entirely different kind of beast and purpose (it's all about handling and is best appreciated on windy roads or at track days on road courses, not in daily stop and go traffic). The Outlander is a nice comfy 4WD "appliance" (not sports car) that I hope to keep with little maintenance past the generous warranty (historically I keep vehicles 7-10 years and the Esprit is the exception at over 22 yrs, but annual driven miles are very low.).
Maybe it's time that you drive a WRX. The powerband is fine, and the car is as good a "daily driver" as any other Subaru offers.
I'm on my second WRX, the most recent being an '09 model. ...Oh, a "boy racer"? I'm going to be 65 in two months.
Bob
So you're saying that "chicks" are more practical car owners than guys and place more stock in reliability than a macho appearance? Hey I can live with that
-Frank
For what it's worth, contrary to what's been said about the Forester XT's engine in this thread, besides the displacement and layout the turbo engine has virtually nothing in common with the normally aspirated engine.
I have the non-turbo, and I sure wish it had these, even if they would be totally overkill:
* semi-closed deck block
* sodium filled valves
* forged connecting rods
So the turbo engine is reinforced in an appropriate manner. And the 2.5T has very useable low-end torque, better in that regard than the 2.0l turbos offered overseas. Plus the Forester is one of the lighter crossovers in its class, making the application more appropriate.
For reference, my Miata makes 140 lb-ft at 5000rpm, and the 2GR V6 in my Sienna makes 245 lb-ft at a fairly high 4700rpm. The F-XT produces 226 lb-ft at just 2800rpm.
Makes my minivan's V6 seem downright peaky!
The only engine I can think of in this class that peaks sooner is the Tiguan, with 207 lb-ft at a claimed 1700-5000 rpm, and the Forester XT is easily quicker.
Edit: for reference, the 2010 V6 in the Outlander makes 215 lb-ft of peak torque at 3750 rpm, while the 07-09 made 204 lb-ft at 4000rpm.
Not knocking the WRX at all. The engine is appropriate for the sporty nature and would be a fun vehicle if I was looking for something like that. My point is for a heavier CUV I think the 3.0 engine is more in line with that kind of vehicle
(non-stick 4WD towing/cargo/people hauler weighing several hundred lbs more. )
For the big family duties, I opted for the 149 cubic feet of cargo acreage you just don't get outside the minivan segment. That's more than double the space. Plus you can lay a sheet of plywood inside and still close the hatch! :surprise:
It's getting too warm and fuzzy in here, quick, let's disagree on something. Paper or plastic?
Actually they managed a 5.3 sec 0-60 for the F-XT. Which was faster than that of the Nissan 350Z :shades:
-Frank
Edit: Here's what Car & Driver said in their August 2003 review:
The force-fed flat-four's combination of torque, gearing, and weight will get you a blazing 0-to-60 time of 5.3 seconds and a quarter-mile of 13.8 seconds at 97 mph, just 0.3 second slower than an $89,665 Porsche Cayenne Turbo
The current generation F-XT isn't as fast but has a broader powerband.
Subaru requires premium; Mitsubishi recommends it.
And Hyundai's 3.3L V6 242 hp with 10.4/1 compression only says unleaded regular
* Roof rails could be optional, 95% don't need them: they increase noise level. Or they should make them retractable
* The current 6-speed transmission is excellent. Very smooth. Twin clutch transmission would be nice. I've read they plan it for the next year Outlie model in some European market.
* Brembo brakes would be nice, but along with Twin clutch it would push price into upscale territory. But why not? None of those MDXs, X3 or GLKs have Brembos and Twin clutch.
* How about 19" sport tires (btw available as catalog option)
* We gotta have some gadgets: it's Mitsubishi. 4G based navigation with Internet access and in-car Wi-Fi hotspot,
* Or How about V6 turbo?
The Hyundai is out of scope for this thread, but I'll bite.
Outlander 230HP 3L V6: 76.7 HP/L (assume max HP w/Premium)
Outlander 220HP 3L V6: 73.3 HP/L (assume 10 HP drop w/Regular)
Hyundai 242HP 3.3L V6: 73.3 HP/L on Regular
Forester 224HP 2.5L H4 Turbo: 89.6 HP/L on Premium
None of us know that the Outlander loses 10HP if Regular is used instead of Premium, but assuming it does (4-6HP seems more realistic to me but I'll accept 10 for the purpose of this discussion) it makes the exact same power/liter that the Hyundai does on Regular and beats it with Premium. As expected, a turbocharged engine beats both.
EPA economy estimates:
Outlander V6 AWD: 18/24
Forester I4 Turbo AWD: 19/24
Santa Fe V6 AWD: 17/24
So smaller engine = better city MPG but they're all the same on the highway. An extra gear or two in the Forester's AT and it could really shine here.
Manufacturer powertrain, bumper-to-bumper warranty:
Mitsubishi: 10 yr/100K miles, 5/60
Hyundai: 10 yr/100K miles, 5/60
Subaru: 5 yr/60K miles, 3/36
All three include roadside assistance during the b-b warranty period. However, based on past experience I really prefer the 100K powertrain (I had a Mazda that blew it's trans at 76K; my ex-wife had a Camry that blew it's trans at 62K). It's insurance, really, and the longer the policy the better.
- If you care about straight-line performance, get the Forester.
- If you want the best slalom performance, get the Outlander and replace the OEM tires.
- If you want that possible extra city MPG get the Forester. Or really, consider FWD or another kind of vehicle .. the same 3.3L in the Sonata gets 249 HP and 19/29 economy.
- If you want the best all-around visibility get the Forester.
- If you need 3rd row seats skip the Forester.
- If you want a rear-backup camera get the Outlander. If the other two have it their web sites aren't mentioning it.
- If you care about warranty go for the Mitsu or Hyundai.
- If you don't want a 4 cyl get the Mitsu or Hyundai.
- If you want capable-but-boring get the Santa Fe.
- If you want a modern interior and more state-of-the-art electronics like rain-sensing wipers, get the Mitsu.
- If you want your accessories like BlueTooth to be integrated, avoid the Hyundai.
- If you want a premium audio system get the Mitsu.
- If you frequently haul long items like lumber, get the Outlander since it has a split-hatch.
- If you want a 1-person bed get the Outlander. Slide the passenger front seat forward & passenger rear seat back, remove the front seat headrest, and fully recline the front seat. The top of the front seat goes flush with the rear seat cushion.
- Etc.
None are bad vehicles; drive them all if you want and pick the one you like the best.
My only comment was somehow Hyundai is getting a 10.4/1 compression engine to run just on regular. It wasn't a sales pitch for the Santa Fe (bringing on all the other comparisons you made), rather wondering out loud what changed in the Outlander that already has variable valve timing in the 220 hp version of the Mivec. In the old days that kind of CR would have mandated Premium.
So what extra is Mitsubishi doing and how does that compare to the technology of what Hyundai is doing? (engine only please if you happen to know). This isn't me stating Hyundai is better, but wanting to understand the different approaches. If by chance you have seen some of my older posts in the past you know I'm no fan of premium fuel (and in the case of CUVs I'm no fan of turbocharging) :shades:
So you'll lose a few horses (probably not quite 10hp, I agree about that). But you also may not be getting quite as good mileage, too.
Car & Driver had a good article about that. Their conclusion was you may as well use what's recommended.
Having said that, I bet the mpg drop is small.
Hyundai deserves the "Most Improved Player" award.
Ford did wonders with EcoBoost, too. Twin turbos, impressive power, and you can run regular fuel.
Who else? On paper, GM's Equinox is amazing - direct injection on both engines (i4 and V6), class leading power, class leading fuel economy. Sadly in real-world tests it hasn't been fast, and hasn't been particularly efficient, either. Still, give their engineers credit for aces on the EPA tests, at least.
GM got 264hp out of that 3.0l V6 with direct injection, so there's a benchmark if we're looking for one. And that is on Regular octane.
*** getting back to Forester and Outlander...
Both Mitsu and Subaru have their work cut out for them. What was near the head of the class a couple of years ago is merely so-so now.
Subaru ought to get the 265hp version of this engine from the WRX in the Forester XT. That would put it up with the RAV4 and Equinox near the head of the class. Torque is already there, but even though torque gets the job done, it's horsepower that sells cars. Bring back the manual trans, even if few are sold it makes for great headlines. If not at least give it the OB's auto.
The non-turbo is actually OK, the PZEV makes 175hp and that's close to the head of the class (I say drop the non-PZEV, it's not as clean and less powerful). It could use the CVT transmission from the Legacy, and if you disagree take a peek at the EPA numbers for that vehicle: 23/31. :surprise:
What about the Outie? The base 4 banger makes 168hp, so it's time to give that engine a boost. Wasn't Mitsubishi a pioneer in Direct Injection? If GM can get 180hp out of theirs, Mitsu can, too. Honda and Toyota both boosted the output of their base engines.
Same for the V6. Direct Injection would boost HP and MPG at the same time. Plus DI has a cooling effect, which likely means they may be able to drop the premium fuel recommendation. It's win-win-win.
Incremental improvements are OK, but let's be honest, competitors are improving by leaps and bounds. The old Equinox V6 made just 185hp!
Toyota made it standard on the Highlander Sport. The 2011 Sienna LE also gets it. They have the right idea - and it's not bundled in expensive packages. Not sure when/if the RAV4 gets it.
I hear Nissan is coming out with a Navi for $400 that will be offered across the board, and you can add a backup cam to (aftermarket is $99, let's see what they charge). Now you're talking:
http://blogs.automotive.com/6611001/miscellaneous/nissan-to-release-400-gps-navi- gation-system-for-cars/index.html
Nav systems are cash cows for the manufacturers so I'm sure Mitsubishi will keep pushing the envelope to stay ahead of these more affordable systems, especially to justify the cost.
Not sure how the market will respond. I'm sure there will be demand for both - audiophiles who want the $2000+ system that do everything, and practical folks who want the highlights only at a lower price.
(sorry, it was a long post that covered several subjects, so I'm responding to one topic at a time, so each subject is threaded)
If you wanna haul lumber get an AWD Sienna, because you can fit a sheet of plywood inside and still close the hatch. You can get drywall home even on a rainy day. Even a Suburban can't do that. A pickup could but it would be wet.
I guess you could load it on the roof of a any compact crossover, but as mentioned earlier the GT doesn't have roof rails, so you'll need to add accessories to do that. IMHO that makes it far from the ideal vehicle to haul lumber. An XLS V6 would be better suited.
The seat folding flat feature is nice, my Sienna has that, too. Careful not to scuff up the interior.
I can't live without a roof rack. Before I got my van I did this:
CarSpace is having trouble showing the image, so here's a link:
http://www.carspace.com/ateixeira/Albums/misc/DSC00477b.JPG/page/photo.html#pic
Actually my Forester does this too (both my 1998 and 2009 models).
Reclining rear seats are indeed quite nice. :shades:
That was s picture taken recently in bookstore by iPhone from the actual printed CR magazine.
Maybe you saw a special edition/buyer's guide? :confuse:
I do have that, the "Buying Guide 2010" book and on page 172 they rate the 07 Outlander "Much Better than Average" but the 08 is merely "Average". On page 142 they split the difference, and the forecast is "Better than Average".
They don't list the Forester turbo seperately in that book.
Any how, I'm not disputing the drop in score on the 2009 turbos, but that only affected a few VINs as I listed above. The 2010s will score higher, but that will only be reflected a year from now.
Looking back at the Buying Guide 2008, the wheel bearings hurt the detailed score in that category on 2001 models (half black dot = below average), but by 2004 Subaru earned the red dot in that category (Much Better than Average). That's because they changed the design to a sealed type wheel bearing for model year 2003.
It's not uncommon to have a big gain (or drop) in reliability from one year to the next. It simply means they applied a fix, and it worked.
I'm sure Mitsubishi does the same thing. I see a few black dots that turned red.
extends the deck area on the Outlander. One reason I passed on the RAV4.
I think I'd still rather have the plywood on the roof, though. You may have scratched up the plastics on the inside of your D-pillar.
Edit: I was wondering why the RAV4 could not do that, and then I realized - the swing out door, of course! You'd need about 20 feet (*) of clearance behind you.
* - hyperbole
http://answers.edmunds.com/question-Having-trouble-Bluetooth-setup-Pushed-button- -start-Can-Mitsubishi-Outlander-80986.aspx
The problem with the roof loading the lumber is you are lifting weight up high vs sliding the stuff in on a low tailgate.(I loaded it by myself direct off the Home Depot dolly)
If you come to an abrupt stop you better have the load very securely tied down for things on the roof!! (I had straps over the rear, but the folded seats stop any forward movement) Not having cross rails installed yet also made this the only option anyway.
I snapped that pic after I'd unwrapped and untied the plywood from the roof. I bought 9 sheets (plywood/OSD pre-primed) that day. In the pic I think there were only 4 left.
They were very secure, without a doubt. Something my 1998 model had that I miss was the 4 sturdy handles in the roof rails themselves. They served as excellent tie-downs.
The 2009 has a loop towards the back, but none at the front.
As a trade-off they increased the roof rack capacity to an impressive 175 lbs. I believe the Outlander can carry 110 lbs, still decent.
I hear the manual is thick as a book, eh? And there's 2 of them?
Have you read it cover-to-cover yet? The holiday break is your chance.
I read the manual on my 1998 Forester and took notes as I went along. I learned 7 things I didn't know. And I'd owned the car for years.
Cheers. :shades:
My Sienna came with a book-sized manual and a DVD, but the video is mostly to show you how to flip and fold all the seats. 7 of the 8 seats fold, all in different ways!
Outlander front seat folds flat, so if you take advantage of that you probably get largest and longest cargo space in class.
And with the clever split clam-shall tailgate design you can leave opened just the lower part of tailgate, so that lumber could extent even longer: no roof rails needed.
Other advantages of internal cargo placement: the weight limit is 10 times higher, better aerodynamics / gas mileage / noise level, weather protection, safety, easier / faster to load / mount.
This design also simplifies transportation of bicycle.
I believe no other vehicle in class could offer this level of cargo flexibility. Passenger flexibility is amazing too: it is probably the smallest vehicle with 3rd row seat; the full length bed option was already mentioned.
Yea, RAV can't do that.
I guess, it could be a special edition, since it was thin. The cover had title something like ‘Best and Worst New Cars 2010’.
“merely Average"? Hmm. Outlander was Consumer Reports top 2-5 most reliable in class at least 4 last years:
2006, 2007, 2008, 2008J, 2009
