Honda Pilot Steering Questions
We just bought a Pilot last Friday and I had to bring it in on Monday because I was feeling vibrations in the steering wheel when I hit 70 on the highway. They ended up giving me 4 new tires. Everything seemed fine for a day and then the vibrations started again, They told me it was typical in an SUV until the tires have driven about 200 miles. Has anyone else experienced this?
Joe
Have the service advisor drive with you in the car and get him to agree it's a problem then have him work with the techs on a solution to the problem.
I had a bad wheel bearing in my '04 Audi and it took two visits to the service department before they fixed the problem. Initially they wanted to blame it on my winter tires.
I just purchased a 2008 Pilot and picked it up 1 week ago, I had had it back to the shop twice already and it's going in again tomorrow for a slight vibration that starts at about 65 mph. It gets a little worse at 75 but not much different after that. The first time at the dealer they adjusted the Tire Pressure, it did nothing, next they rebalanced my front tires, that did nothing. Who knows what they will do next. I traded in an 04 Toyota Sienna minivan with 72K miles that ran smoother than this does.
They mentioned a Drive shaft, I'm thinking if it is it's out of balance, or a tourque converter (Transmission) Either way they have had the big shots drive it and agree there is a vibration. If they fix it great. Otherwise I love the vehicle. I can be a pain in the [non-permissible content removed] for a 30K price tag.
Bob
SUVs and Smart Shopper
very loud.
didn't check with service center yet.
I am glad that I just lease this car instead of buying.
Love everything else.
Bob
Anyone else notice this after switching to SUV tires????
GSP 9700 Vibration Control System
Hunter Machine - Forced Variation Balancer
http://www.sullivantire.com/xcessorize/hunter.aspx
It would be interesting to find out from other owners if they have noticed this also after going to a SUV Tire.
For me I would start with this easy one first before dig deep into something else. Dealers may not have this Hunter 9700 machine, why not give them a call to confirm.
My point is that SUV tires may not be appropriate for the suspension set up on the Honda Pilot. Honda engineers chose the GY Integrity tires for a reason. My thinking is that the GY's are lighter in weight, have less rolling resistance for mileage and have a softer side wall for that car like ride. It might be that the SUV tire market by design do not work that well with the Honda suspension set up.
After 6 months, I got rid of the POS and got a Dodge Durango XLT with the small V-8. I've had it for 3 years, 56K miles and not ONE problem of any kind.In fact, I've still got the original tires, and it's as smooth as silk at highway speeds.
My advice-start looking for a replacement vehicle and don't bother waiting 6 months. The vibration probably isn't going away.
Read about my exact problem here then decide for yourself if you would like to join the cause.
Stretch
I have to take the Pilot back to the dealer to get Lojack installed and have this issue looked at- judging from prior posts this fix looks to be a long-term repeat process. Has Honda come up w/ an official reason for the steering wheel shake, or is it just a quirk of a new Honda model all Pilot owners are helping to develop and refine? I plan to upgrade to 20's w/ performance speed rated SUV tires, so maybe that will help.
The vibration does not occur at any other time, not even when turning a corner. It usually just happens from a dead stop.
Anyone else experience this?
I have seen other posts about hard bumpy rides, and the suggestions of adding an Acura vibration pilot subframe brace, changing the old BF Goodrich's to something that is more suitable for off road, ie, Michelin LTX M/S, or swapping the Shock Absorbers, and hopefully improving the ride. Any users with suggestions about solving the hard ride issue, any problem solvers welcome. Thanks
1) For mcintyred -- it's been a month now since your fix, has the issue returned in any way? Is there a chance you can give me details of the honda dealership that finally resolved your problem (company and contact name).
2) For dougd2 and angelo o -- have you had any luck with getting you issue fixed?
Thanks for any help you can give.
My issue is indeed 100% solved. I got the same response that perhaps the noise was a characteristic of the model but when I asked the questions as to why it only happened when the wheel was turned to the right and when I suggested we drive a 2012 off the lot the service tech said they would look a little deeper. Honda Canada had them troubleshoot the rack as I mentioned above searching for traces of metal in the power steering fluid.
I don't mind giving you the dealers name and contact info but would prefer to do it by private e-mail, just click on my profile and send me a message.
I suggest you get your dealer to strain the power steering fluid searching for filings from a worn rack. Please contact me or at least keep us posted.
I'll definitely keep you and the forum posted on any progress I'm able to make.
I look forward to hearing from you.
I am so glad I came across your post. My husband had me search common problems with steering vibrations in our 2011 Honda Pilot. So far we have had our power steering pump replaced and then we were told our rotors needed to be machined and new brake pads put on. As expected the vibrating still occurs. We have only owned our Pilot for 6 months. I will post a response as soon as I have the steering rack fixed.
Thank for posting, I'm taking mine in to the dealership this weekend for the same problem.
I did a long drive from vancouver to san francisco loaded with my family of five. way down hill from the border of seatle and calif at around ( 108km ) of speed ... men its a terrible experience for the exted of vibration.i paid $61000 canadian for this car and this is what ive got in less than 2 years..
the whole trip end up really slow for 22 hours of drive BC to SF because of this vibration.
Contrary to popular belief, Honda does not make their own Power Steering Rack. A third party actually manufactures and sells these factory Power Steering Racks directly to Honda. Honda then installs these Power Steering Racks in your Pilot at the factory assembly line.2010 to 2013 have the same sterring rack assy..
My apointment is next week and i will update u guys for the outcome..iam 100 percent sure its the sterring rack i did rotate the tires inspect the rotor the pads everything in good shape.
If iam going to replace the steering rack every 2 years better i look for onother brand.
What more if we use this for off road..try everyone down the hill for at atleast 100km of speed.
do it while its not too late..
The tires treads are at about 5/32 and both the dealer and the tire shop said they are okay for a few more miles.
Should I take it to the dealer and ask them to look at the power steering, drive train, what?
thanks.
