Had engine replaced in Chevy Tahoe96 now trans leaking
                    I just had the motor replaced in our chevy tahoe 96. we were told that the leak cannot have anything to do with the motor change and they did not replace any seals when they worked on it. And the leak only started AFTER the motor replacement and 3,000 dollars later. I was wondering if that is true and also if it would be okay to put a sealant in the transmission fluid. I live in northern Minnesota where it has been below zero for about 10 years now.
