Lexus RX Transmission Problems
1910121415
  • tickedatlexustickedatlexus Member Posts: 8
    I'm in Columbus, OH - the dealer contacted Lexus about 'good willing' half of my Lexus rebuilt tranny. I am nervous though, my tranny fluid is more red than purple & smells burnt. I haven't taken it back to be checked yet.
  • bendorrx300bendorrx300 Member Posts: 11
    The Lexus dealer did the replacement work, replacing the entire transmission, not just the TC and pump. That second transmission failed within the one year warranty period, and Lexus followed the warranty to the letter. The local Lexus shop was very professional and the experience was painless. The original transmission failed a few thousand miles out of warranty, hence the "good will" gesture of cost sharing.
    The analytical lab stated on the analysis results that wear was "severe", and posted a red stop sign on the form. This analytical lab is accustomed to performing spectroscopic engine oil analysis of piston aircraft engines wherein the engine block is aluminum. Fortunately, our RX stays on the ground.
  • flsjr55flsjr55 Member Posts: 16
    My transmisson went out when I was visiting out of town. I was close to a Toyota dealer who replaced the transmission. When I contacted Lexus Customer Service they wanted repairis made at my local dealer but did not want to pay $500 for towing. Afer repairs were completed I was instructed to fax the bill tp a certain person at Lexus Customer Service. It was several weeks befor they called and advised the amount they would pay.
  • angela_dangela_d Member Posts: 1
    hi, can you please inform me on how long your Lexus was running without problems after you changed its transmission at 145K point?..do you think it's worth to change a transmission in Lexus and go on with the car?...pls advise/share your experience..thanks
    I only have about 6000 miles on the rebuilt transmisson.
  • treelady8treelady8 Member Posts: 2
    My RX 300 has almost 140,000. (It's a Silversport, if that makes a difference.) I have NEVER had anything go wrong with it (except the usual wear and tear, brakes, etc.) until just recently. The driver's side door remote key would not open or close. Needed actuator (sp?) $400. I have never brought the car in for service. My husband always changed oil. We have NEVER had the tranny fluid changed. In the past, it seemed like ever time I brought a car in (not Lexus) something else would go wrong with it. I feel I should change the tranny fluid. They recommend it at 60,000 and 120,000. I'm afraid if I change it, something will go wrong with it! I just bought my 3rd Lexus. 2008 RX350. I hope I have as much lucky with this Lexus as my previous ones. I think they are GREAT vehicles!!
    The RX 300 tranny problem is certain model years - what year is yours? I've enjoyed mine too, but with such a big tranny problem & they didn't issue a recall - what a joke. My driver's side lock also won't work with the key - so I lock it manually. My passenger rear door lock also has a problem - can't open the door from the inside & must manually unlock it - real handy. I've replaced 2 O2 sensors - $500 each!!! Lexus is just too expensive to maintain.
  • 2001rx300ga2001rx300ga Member Posts: 1
    Sounds familiar. I just had the same episode and $4100 repair on my son's 2001. The transmission repair shop found it nearly disintegrated inside with metal throughout the cooler. A total rebuild by hand with improved parts and a new larger cooler. The other cooler had an inadequate flow and thus on a long trip it gets hot and fails. I am drafting a letter to Lexus and will use this forum as proof the problem is not isolated and if not satisfied will look into reporting to federal agency in charge of recalls.
    The dealer won't know to add a different cooler and may be why others' replacements have re-failed.
    My Lexus was a 2001 and not AWD. Also replaced 1 02 sensor and radio. I don't believe 2000-2002 were good years for the RX
    Mine is a 2001 RX300 Silversport AWD.  I couldn't find any info on changing the tranny fluid in the manual. My  husband was changing the tranny fluid when it said on the tranny dip stick that it never needed to be changed. I called the Lexus dealership they said it should be changed at 60,000 and 120,000. Makes you wonder if they say that to get more business. Also my husband changed tranny fluid on his Highlander. It had the EXACT same tranny!  Same model number. Interesting...  As I said in earlier post my 2001 RX300 has almost 140,000 miles. I have NEVER brought in for service. And have never had anything go wrong with it except usual brakes, battery etc. And the driver foot actuator needed replacing just recently.  No complaints, that's pretty good for car with 140,000 miles.  My husband does all maintence!
  • rquinn55rquinn55 Member Posts: 1
    My RX 300 only had 64000 when the transmission blew. Has anyone had any luck contacting Lexus and getting some satisfaction?. The cost of repair was $4200
    Contact Lexus Customer Service. Save all your receipts. Lexus paid 35% of my $3700 repair bill.
  • lserlohnlserlohn Member Posts: 10
    just learned that rav4 owner had a class action on its bad transmission, I am wondering why there is no action from lexus owners. http://wheels.blogs.nytimes.com/2010/07/13/toyota-extends-warranty-on-troubled-2- 001-3-rav4/
    http://www.courthousenews.com/2009/11/19/ToyotaRAV4.pdf
    Quote
  • slsrmeslsrme Member Posts: 2
    I just had Lexus service my 99 rx300 tranny in March 2011. This past weekend while driving back from vacation my transmission starting whirring and slipping. It would only shift through the gears after turning it off and letting it sit for a few minutes then starting it back up. This has continued since Saturday and so I took it to my Lexus dealer and they are telling me I need a $4500 transmission. It does seem odd that there are so many of these exact same problems accurring even after Lexus services the tranny. Isn't it their job to inform you when they service your car of any impending damage that may need addressing? I certainly am all for a class action if enough people come forward. Since last year I have spent several thousand dollars in repairs with Lexus, and now they are milking me for more.
  • naperleighnaperleigh Member Posts: 7
    Sorry to hear you are joining our RX 300 Tranny club. You want to fell better about yours ...mine cost me $5500. Needless to say I will never deal with this dealer again ( I purchased two Lexus from him). Mine happened a year ago and is still working. Many crap out a second or third time. Good luck
    Call Lexus Customer Service and explain the problem and ask why no recall? These vehicles should have been recalled since there was a design flaw. Lexus has known about the problem and done NOTHING.
    edited July 2011
    Can anybody answer me: WHY NO CLASS ACTION??????????????!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    I think any owner who suffered such experience is willing to pay some bucks on the class action. Toyota will definitely loss, see what happened to RAV4 Owners.
    IF AND ONLY IF WE ACT TOGETHER!!!!!!!!!
    (I am not a lawyer, otherwise, I would probably take the head of this action)
    I also wondered the same. My only thought is there are not enough vehicles involved to make it worth an attorney geting involved?
    I called Lexus and they are forwarding this issue to a higher up. I informed them of the knowledge that this issue is not an isolated incident and has occurred it seems in all 99-2002 RX 300 owners’ vehicles. I am going with my employer to see his lawyer tomorrow and taking the documentation where Lexus completed "preventative maint." on my transmission in March of this year. I am most assuredly going to mention this site to my lawyer and also the safecar.gov site which also has a plethora of complaints of the exact same nature as the ones posted here. I will certainly keep you guys posted as to the outcome. The dealership actually has my car as we speak, so the main branch of Lexus stated they would do all they could to keep me and the dealer happy.....we'll see.
  • garingerbgaringerb Member Posts: 1
    We just bought a used 2000 RX300 from the dealer less than 3 months and 2000 miles ago. They claimed their mechanic went through the whole car, made some repairs and it was in great shape. Now my transmission is busted and its going to cost $4500 to fix. That is about 50% of the price we paid for the vehicle. It has about 122,000 miles in total on it. I find it hard to believe their mechanic couldn't have seen an issue within such a short period of time. They indicate its my fault for not buying the extended warranty, but what product breaks down like that. And even if it does, wouldn't you want to help a customer somehow to keep them loyal? I'm all for a class action suit.
    While it is very likely the mechanic could not have detected the impending failure they should have known the history of the '99-00 RX300 in this regard and at least forewarned you.
    is it a "Lexus Certificated" one?
  • pamfinleypamfinley Member Posts: 1
    2000 RX300 FWD 103k Regular dealer service. This week it had Tranmission failure with no warning. Needs rebuild. Contacted Lexus today.
  • lbercovichlbercovich Member Posts: 1
    same thing here...2001 RX 300...transmission just went out....won't buy a Lexus ever again
  • stw962stw962 Member Posts: 2
    Who was the person to fax bill to and how much did they pay on bill ? Thanks. My daughter's transmission just went out 7/13/11 on 2002 RX300 AWD. Waiting on estimate.
    Count me in lawsuit.
  • deannalucasdeannalucas Member Posts: 1
    i bought my used 2002 300rx 3 years ago with 110,000 miles. tranmision went out in 1o months. local auto shop replaced it for $4000. it lasted for 13 months. just over the 12 month warranty. i had to purchase another new transmission but the mechanic felt sorry for me and did the labor for free.so i paid only $3000. the mechanic put in a certified lexus transmission. that new transmission (#3) lasted 2500 miles, about 3 months. lexus wants $1500 to replace their certified transmission. the local mechanic doesnt want to spend any more of his time with this lemon. so i am stuck in no mans land with a car i cant gert rid of because it doesnt run again for the 3rd time in about 24 months. i told leus customer service that this was a problem with their car and they told me that there had never been a recall on these cars.
    i feel like the problem only kicks in with these cars when they near 100,000 miles. they are conveniently out of warranty and no longer their problem. when i told lexus that the internet was full of complaints on this car, they told me that they couldnt control what people might put on the internet. i now need my 4th transmission in 25,000 miles and i have to pay again even though its under warranty.
  • mrbostonmrboston Member Posts: 43
    Lexus motto "The Relentless Pursuit of Perfection is a lie and false advertising.
    Go to small claims court and show the judge the Edmunds .com list of al lthe RX 300 transmissio nfailures. I received ful laward $5,621.15
    Lexus is a liar make them pay!
    "...local auto shop replaced it.."
    I would suspect that there is a really good chance the fault lies with the engine/transaxle controlling ECU. Has anyone addressed that possibility or changed it out..?
    Also, the ECU MUST match the model year and revision date of the engien and the transaxle, you may have a mismatch.
  • kwbuggykwbuggy Member Posts: 11
    Eleven years old and over 180,000km!!!! I would say that most cars suffer major breakdowns at this point in time. This whole thread seems to be composed of people with old, worn out cars expecting miracles just because the name Lexus is on the vehicle. Get a grip, cars, just like people, wear out over time. Looking after yourself by having good quality healthcare or your car by having it maintained exclusively by Lexus dealers may extend life somewhat but everything wears out and certainly buying an eleven year used old car of any brand with over 160,000km (100,000 miles ) for $9,000US is asking for trouble. There must be a group of underemployed lawyers behind the concept that a class action lawsuit relating to ten or eleven year old cars is a worthwhile cause. Only in America I guess!
  • la4meadla4mead Member Posts: 347
    edited July 2011
    I feel for the owners who have to spend thousands of dollars to rebuild their transmissions. This is an obvious area of concern.
    However, many do last much longer than 100,000 miles, but there are a couple issues that combine to cause problems, like has been stated and re-stated on this and many other forums over and over.
    Firstly, there was the original design which was not intended to be a stout truck-like transmission in a car that was designed two decades ago, and marketed to be anti-truck like. Anyone who intends from to keep this type of vehicle a long time knows transverse automatics in heavy vehicles have to deal with extra heat, etc. and needs to perform additional maintanence the manual or dealer networks don't specify or support. Merely stating "dealer service" means this extra diligence was not performed. I had more than one dealer tell me they have never serviced these units even when requested. That's when you know it's time to take it somewhere else or learn to DIY. But be warned - the neighborhood lube shop and transmission shops don't carry Toyota Type IV fluid which is a proprietery fluid. Unless requested otherwise, they use the stuff they get by the drum" Dex/Mercron and add an additive to simulate the Type IV fluid, which can be a cause of problems.
    Secondly, there were some early units that did have issues and Lexus TSB's covering them under the original 7-year/70,000 mile warranty. Lexus did take care of these customers (but sometimes it meant complaining more than once).
    Thirdly, because of the car's popularity (and many were leased), only dealer recommended service was performed, and many were traded in or otherwise sold used. 13 year old vehicle - of any make - that was only treated to dealer specified service means you - the second-hand owner- should be on the lookout for this kind of trouble, and I don't think that's something you can sue for.
    Additionally, because the transmission design had many updates during it's tenure, a third-party rebuilt unit that was sitting on a shelf may or may not have all the updates that were compatible, and could be a source of future problems. We are seeing reports like this come up more often they age.
    Lastly, there were a good majority of these cars that remained reliable for well over a hundred thousand miles, sometimes double that. But they don't last forever, and eventually need repair. At that age, I don't think a lawsuit would be the best way to settle it.
    Deannalucas,
    Your situation is very unfortunate and extreme. Your neighborhood mechanic made a profit both times, but did not feel obligated to make it right after the second failure. I don't think you will get satisfaction from Lexus since you took your loyalty elsewhere. I could be wrong here, but I know Lexus was "helping" owners after their original warranty expired to earn their loyalty, not because they felt responsible to.
    If it were me, I would tactfully put pressure on this neighborhood mechanic to set it right and correct the situation. The mechanic needs to be sure to get the correctly rebuilt part (or do it himself with verified updated parts) with all appropriate updates, and you've already paid her/him full retail twice, even though he/she gave you a break on the cost of the second (he still made a profit at $3000) or refund your money (doubtful). If he doesn't I'd then take legal action, but not before I'd exhausted firm but polite requests.
    If you need to go somewhere else, be sure to let them know you've done your homework. You need: the correct parts updates that match your vehicle and make it reliable, correct Type IV fluid, and you are getting estimates because there seems to be a lot of "room" in the cost of these transmissions based on what you've read here and on Lexus Owners Club forums, and the price seems dependent on the vehicle's percieved value.
    Please be sure to share your findings. I hope it works out well for you. Good luck!
  • jiminfresnojiminfresno Member Posts: 3
    Transmission went yesterday, fortunately it was in my driveway. Car was bought new in June of 2001 and was babied, never towed anything, had 88,000 miles, serviced regularly, transmission serviced at 30,000 and 60,000 miles. I am having it towed to a local transmission shop. He said the worst case scenario would be $4400.
    I am hoping I don't have to replace the transmission. You can put it in reverse but it thinks its in neutral. You can push down the accelerator and it goes forward with a noise from the transmission.
    If you engage the ECT (snow) it will go forward and reverse without any noise. When the tow truck picked it up today it went into reverse and was able to back it up on to the truck with noise.
    Will report back on the diagnosis. Like many others, when you service a car regularly, do not tow anything, wife only drives, 9000 miles per year, and you buy a car for reliability you don't expect to spend $4400 on a transmission at 88,000 miles.
    Very disappointed in the Lexus name and quality. I thought with the extra money I was buying a vehicle that would be reliable. Add to that the Power windows work when they want, and the key no longer activates the door lock on the driver's side, and the fan in the dash sometimes sound like its rubbing something I feel like I have a Kia. On the outside it looks new as I have faithfully waxed it 4 times a year. Very disappointed.
    "...I feel like I have a Kia.."
    You should be so lucky.
    I suggest that you consult with Lexus Customer Service before having a non Lexus dealer make repairs. If it being repaired at a lexus dealer there is a good possibility the dealer and Lexus Corp will contribute toward the cost of repairs.
    YOUR MESSAGE READS AS A LEXUS ATTORNEY.
    Lexus is falsely advertising when it says, "The relentless pursuit of Excellence."
    I sued Lexus ins small claims court and won for their faulty transmission.
    Lexus service manager finally admitted it was a piece of junk. The failure rate on 2009 - 2001 Lexus RX 300 AWD is tremendous. How do I know
    I had two cars and they both went out at almost the exact same time.
    These cars were babied.
    After having bought the first LS 400 in 1990 and seven other Lexus,
    NO THANKS I'm done. Lexus and Toyota quality have gone way down hill.
    The worste part is Lexus refuses to takeresponsibility until they show up in court>>>>>>
    Can you say what the cost of the attorney was and what the settlement was?
  • accproaccpro Member Posts: 4
    I am so glad to hear that you took Lexus ins small claims court and won for their faulty transmission.
    My Lexus 2000 and my sister 2009 Lexus Rx3000 transmissions both had to be replaced after driving for about 90,000 KM.
    The failure of my Lexus 2000 had almost caused my life in the HWY. The transmission stopped functioning a few second after I was exiting the HWY to the ramp. The car suddenly and completely locked on me. The engine was running, but the car could not go nowhere. I had to get a special tow truck to lifted my car to the garage. Luckily this did not happen in the HWY. This would had caused a chain reaction car accidents and very serious injury.
    Every time when I am passing by the place where my Lexus transmission fail. I have a nightmare the next day. It is very unpleasant experience in my life that I had with Lexus. I tried to forget about it. But the terrible things always stayed in my mind.
    edited July 2011
    Class Action, who lead this, I will pay 20% of my reimbursement to the leader, if we win, win chance over 90%
    Well I got my update today on the 2001 Lexus Post # 605. I went to an independent transmission shop who is very well thought of in our city. His findings and cost to repair are below:
    First of all the transmission is bad in your vehicle. The fluid is full of metal particles and is burnt. The planetary gear train (which is #1 failure) is breaking up causing binding in reverse and forward ranges. There were no electrical problems/codes found when I scanned the systems.
    I have two options I can give you:
    1. OEM reman transmission w/12 month unlimited miles warranty like we spoke about for 2776.27 for the parts and 1249.50 for the labor to install it. 4025.77+tax of 223.91 I spoke to the dealer and they wouldn’t/ couldn’t give me details of any upgrades/updates that are done to the OEM transmission. I am sure there are some though
    2. Jasper reman transmission w/36 month or 50,000 mile (whichever comes first) warranty. That transmission has a cost of 3335.00 and does not include fluid which would be 62.93. With labor this option would be 4647.43 +tax of 273.49 Now the Jasper reman has 7 upgrades to the transmission which they describe as critical items with the main ones being tig welded planetary gears and valve body upgrades.
    Also I recommend an external cooler w/either option as added insurance from overheating the transmission fluid for 47.95 for the part and 170.00 labor to install it.
    PS: a 10% labor discount is not included in above prices but will be discounted at invoice time.
    Interesting enough I emailed Lexus yesterday morning and just heard back from them I am posting their comment below:
    Thank you for contacting Lexus Customer Satisfaction. We are dedicated to providing superior service. In circumstances that require our attention, we will assist in the resolution process.
    I am very sorry to hear of the concern that you are having with the transmission on your 2001 RX 300. The best way for Lexus to address your concern would be to physically inspect the vehicle at a Lexus dealership. If you have not done so yet, we recommend contacting the Service Department at your Lexus dealership to schedule an appointment. For your convenience. Once the physical inspection has taken place, should you require further assistance, please contact us at the toll free phone number listed below. We cannot guarantee any financial assistance, but we can certainly discuss your concerns by phone. We apologize for any inconvenience this may cause you.
    If you require further assistance, please respond to this e-mail, or contact Lexus Customer Satisfaction at 1-800-255-3987, Monday through Friday, 5:00 am to 6:00 pm, or Saturday, 7:00 am to 4:00 pm, Pacific Time.
    Sincerely,
    Name Deleted for Forum
    Lexus Customer Satisfactiob>
    The fact that they mentioned financial assistance tells me that they would have provided finanical assistance. However this is a 10 year old car and even though the transmission went out at 88,000 miles my guess is their financial assistance probably would have been a discount or $1000 at most. Since their cost to repair is over $5000, I would have been pretty much in the same place.
    Hopes this help people in making decisions. By the way I did talk to Ammco over the phone, they do not provide lifetime warranties for AWD vehicles only 36 month warranties at 15% of the invoice cost. I asked for a quote for full replacement of a transmission and they would not provide one over the phone.
    By the Way anybody have these problems with a 2001 Lexus RX 300AWD?
    1) A power window that goes up and down only sometimes. Usually a swift hit to the door may make it work
    2) The Key remote locks and unlocks all doors but the passenger door
    3) The fan in the dash at times makes noise like its rubbing against something and then goes away.
    I didn't went to dealer, because I think they would charge me money on inspection, and because I rarely service my car at dealer, so they would probably refuse any help.
    I prefer to install a long warranty one, in the long run.
    BTW, you actually have the external cooler, which is a standard equipment for 01 AWD. Check your front passenger side.
    In reality the external cooler is a component of the towing "package", not the AWD system itself.
    But purely by default you are RIGHT.
    Lexus had already come to realize, due to the HIGH failure rate in the '99 & '00 models, that the RX300 transaxle, modified Camry transaxle, was the weak link in the RX300 design. As an interim "fix" the "optional" towing package was not really an option in '01. The other aspects of the '01 and future RX300's "fix" was to eliminate the rear LSD option and make the VC non-functional via a viscous fluid reformulation.
    Less STRESS on the transaxle if the rear wheels were mostly just along for the ride.
    As of '01 TC was adopted to "enforce" torque re-apportionment to the rear in the event front drive traction was lost.
    It wasn't until DBW was adopted, along with elimination of the VC altogether, in the RX330 series to "protect the drive train" that the expected service life of the RX' transaxle exceeded 100,000 miles.
    The bad news is that the addition of the external cooler only served to extend the service life of the RX300 transaxles, I am now at 80K+ and do not expect to see 100K prior to failure.
  • jbl85jbl85 Member Posts: 49
    So, purely by default, then, you are a glass is half empty kind of guy.
    No, my "glass" is most certainly closer to FULL than otherwise...!
  • seastburnseastburn Member Posts: 4
    My transmission went out after only 127,000 miles, about 800 miles after having the fluid changed at a local Tire World. The fluid used was a "sythetic blend where the owners manual specifies T-IV. My very trusted mechanic of over 15 years assures me that this fluid "difference had nothing to do with this failure. This fluid is only available at the dealer. Could this be "part" of the problem or is this transmission just a lemon? He will be having it rebuilt by Jasper Engines and Transmissions who will be doing 18 "upgrades" to it. Where did these upgrades come from? The dealer had no idea of any upgrades. I've only had this car for a month. We drove a1988 Jeep for 18 years-yes it's been very problematic-yet we have managed to put over 335,000 miles on it. We did this to get our house paid off, which we recently did, and then bought this car. Can't say just how dissappointed we are in Lexus. Looks like this problem is moire common than anyone has thought. CARFAX had nothing on it! It did show that all scheduled maintenance was done at the dealer.
    "Could this be part of the problem..?"
    A most definite YES to that.
    Your trusted mechanic is blowing smoke...Toyota ATF is available, EXPENSIVE, but available, at ANY parts store. And given the KNOWN fragility of the '99-'00 RX300 transaxles I would NEVER place the bet your mechanic did.
    "..upgrades..."
    The main one is probably an external ATF cooler.
    I'm not sure I would buy into, allow, any other upgrades. The transaxle is controlled by the engine/transaxle ECU firmware, change even any minor thing and the firmware supplied by the factory back in '99 might go awry.
    edited July 2011
    Re the cooler:
    "...Lexus had already come to realize, due to the HIGH failure rate in the '99 & '00 models, that the RX300 transaxle, modified Camry transaxle, was the weak link in the RX300 design. As an interim "fix" the "optional" towing package was not really an option in '01..."
    Yes, however right from the beginning in early 1998 which was the introduction of the new 1999 RX300, the "tow package" (including the auxiliary cooler in the passenger front fender) was already included on all models, at least in CA, so it goes back earlier than '01 - these were already included.
    Beginning at the introduction, there weren't any on any lots that didn't have it, until a couple years later (2001 or '02, IIRC) the introduction of the models with "performance package" that had air suspension - and no tow rating - the tow package was not offered on that model, and there was no cooler available with the PP. So the vast majority of RX's sold right from the beginning in '98 had "tow package" with the aux. cooler in the fender, and it was on the window sticker as well.
    After driving, feel how hot the aux. cooler in the fender becomes. There is a lot of excess heat being vented from the cooler, but lots of it is exchanged first by the "standard" cooler in the bottom of the radiator. I share WWest's suggestion of a thermostatic fan for the cooler, I also have an additional cooler right behind it, as well as enlarged exit vents in that inner fender liner. There is a big difference in the temp of the cooler even on hot days.
    Good luck with yours.
    Hello, thanks for the information. Is there a step-by-step instruction on how to install the additional fan or cooler on the existed cooler? Pictures are great, thanks.
  • denni1960denni1960 Member Posts: 3
    OMG... my 2001 RX 300 is doing the same thing. My passenger side window does not power up like it should... it's an up and down thing... then it will eventually go up. The dash noise is exactly like you describe.... I wish I knew what it was... it does eventually go away... but what the heck is that?? My transmission is having problems right now... it was towed yesterday to the mechanic... I don't know what the problem is yet. It has 165,000 miles on it and this is the only problem I've had with it. I guess I've been lucky. I enjoyed reading your post... thanks.
