Toyota Prius Hybrid System Questions
I bouught a used 2003 prius in sept, 2007. Monday I had the oil changed by toyota. Since then it has run harder and louder. Yesterday it stalled and gave me three warning lights: Power Steering, Hybrid Battery, and Hybrid System. I called toyota and asked what I should do. They were closing in about 2 minutes. The guy on the phone told me he didn't know basically. I asked if I should drive it home and he said he couldn't give advice either way. I looked in my manual and it said to drive without excellerating too much. So I drove it home slowly, about 2 miles. When I got home I read the book further and it said I was suppose to park the car and take it to toyota immediately. Why couldn't the toyota service guy have told me that? Why wouldn't he know that about the warning sign I got?
Is there a problem with the 2003 battery and hybrid system that I should know about before I have it towed to toyota when they open on monday morning? I want to go in there knowing something. I don't want them to talk past me and give me the run around.
thanks for any advice you have.
downinbh
downinbh
The first time this happened, I had it flatbed-hauled to Toyota, but when it got there, everything was operating normally, so they couldn't tell me what had gone wrong.
Today it happened again, close to home so I was able to get there and park it. Restarts after 10 and 20 minutes yielded the same "hybrid system failure" result. Then, after about an hour, everything started up as normal, with no hint of a problem.
Any ideas as to what the problem is?
-- Jack in DC
A good technician at Toyota was able to identify the problem through the computer readouts. Since the gas-pedal sensor in my Prius was replaced, I've had no more of these on-the-road failures.
It's been a while since this stuff was covered on the Forum, but IIRC there were around 50 unique complaints in the NTSB database on the problem. There were more reports than that, but some appeared to be duplicates.
Still, I've only had this car for a few months and that's a pretty major problem. What happens when toyota warranty goes out and the computer system fails? I'm not sure I'm so happy with this car or technology.
downinbh
P.S. I've yet to find even one dissatisfied Prius owner.....If there are any. Of course there are dealers that fall short of good service and satisfaction unfortunitely.
I have a 2004.
In terms of battery price, I have heard the whole pack is nearly $3500, but Toyota recommends replacing only defective batteries, not the whole pack, so one is unlikely to pay that much to replace a few batteries.
If I ever have to pay $3500 for batteries, I am moving to a plug-in (hopefully it will be that cheap by then).
I have consistently gotten between 51 and 52 mpg over 47,000 miles on our '04 Prius (except for Dec & Jan in CA, when fuel has the 15% ethanol mandated by the state for pollution control help. Then I get about 48 mpg) I have checked the Prius screen mpg against 2 pencil and paper checks over the years. The screen mpg and pencil/paper checks were within .2 mpg of each other, on one the screen was ~.2 mpg more than my division, and the other the screen was ~.2 mpg less than my division.
By the way, how did I discover I had a slow leaking tire, you ask? When my mileage dropped from ~51.3 to ~50.3 I decided to check the tires, and sure enough, my right rear was down to 16#. Another benefit of the running mpg screen.
a 45 mile average no matter how I drive. If I must drive 55 to get
50 mph my average is ok.
Please tell me how you do it.
Yesterday she experienced some hesitation on her way to the store. After about 15 minutes she returned to the car and when trying to start, the dash lights fickered a few times and the horn beeped. She managed to drive it home without any more trouble but once it was turned off, it won't run anymore. The lights, horn, keyfob and radio all work. When I turn the key, I get nothing. Well the console and dashboard lights, do light up but the engine isnt engaged.
I was planning to have it towed to the dealer but was hoping for some ideas before I get there .. and find out what this is going to cost me. Has anyone here experienced the same thing?
appears just to the right of the normal lights, that blinks on and off. This
error light is not documented any where in the manuals that came with the
car. I can start up the engine after this, and it drives normally.
But again after driving, I turn off the motor, go into park mode, this little
red image of a car (facing left) appears blinking to the right of where the
normal running lights are. It is NOT documented and I can't see any
think wrong under the hood. This just happened on this 2008 model.
if anyone has a clue, please let me know. Email proactivator@mac.com, my handle is foxzcar.
Try the engine off-on routine before doing anything else. That can save you a lot of trouble.
sc
I also experience twice failure as i am driving. with out warning it quits working and the speed nly goes to 35mp having plenny of gas. I turn off engine wait an turn on and woala!! it works!!
:confuse: :confuse: :sick:
Take it to Toyota, let them interrogate the computer to find out why it's croaking. Replacing a faulty sensor will not be such a big deal, certainly not in the $3000 price range.
-- Jack in DC
Bob Wilson
A 2001 Prius with 250,000 miles had the battery go bad. The owner contacted me and the two of us swapped the battery in four hours:
After shipping and everything else, $1,700, and the new traction battery has the stronger, more powerful NHW20 modules.
Bob Wilson
Shall I sell it, as the dealer recommends, or get it fixed? Any other ideas?
Do you still want an analysis?
Bob Wilson
Bob Wilson
Bob Wilson
"a new code POA1F" - this is a hybrid vehicle control computer general error. The subcode is needed to understand what is going on.
"is there a way to charge the HV battery" - Yes but normally at the dealer.
Bob Wilson
