ignition coil on my 2002 rodeo
                    I recently changed the spark plugs on my rodeo with very little problems. That is until I attempted to remove the coil around the number 6 spark plug. After removing the two screws I removed the header and the coil stayed lodged in the cylinder. I attempted to remove it with pliers but I was concerned that I would damage the coil.
Has anyone else come across this problem? Any suggestions?
