Mazda MX-5 Miata Soft Top Problems
Has anyone had a problem putting down the soft top on their mazda MX5 (Miata)? Mine sticks around halfway!
When its cold out and the vinyl is stiff, I do have that stop-half-way problem. I reach back and pull that bar down, that helps it go the rest of the way.
When its warm the vinyl is softer and the problem disappears.
It's not a big deal for me - I can do the whole operation from my seat, without taking my seat belt off.
WLJ
Download the Service Bulletin from here: www.miata.net/garage/tsb/09-001-07-1736a.pdf
I've had to replace my top twice - once by a pro, and yes it is expensive, and another on my own.
I think the pro cost me $900, the 2nd time I did it for $460 (but prices were up to $1100 for a pro). Took me 2 days and boy was I sore. It is *not* easy. Definitely the hardest auto-related task I've ever taken on.
I think I'd hire a pro if I had to do it again.
http://forum.miata.net/vb/showthread.php?t=204460&highlight=drain+cleaning
I have a mk1 mx5 (eunos), it had a new hood before i bought it, with a glass rear window, some say its a mk 2 hood, quite probable but the problem is, i cant get the hood to go down fully, only about 3 quarters, the window is not zipped, its a fixed one, and the glass its self prevents the rest of the top going down fully.
can anybody help? please.
I had a 1993 and got a Robbins top with a glass rear window. It had no zipper as well, but it required that I add a couple of nylon straps that bolt diagnocally from one of the top brakes to another, that helped the top slide down. So basically my 1993 top (NA) was converted to a 1999 style top (NB).
I don't have that car any more, though maybe you could contact Robbins and ask them for instructions for the top that converts from a zipper to a non-zipper style. Unfortunately it was a very complex task. That wasn't the hard part, per se, but you would have to take the top half way off to fix that if it wasn't done.
All i know is I love the car, and hopefully one day i can get round this problem, but....Thanks for the reply!
NA = 1990 to 1997 (there was no 1998 model, at least in the USA)
NB = 1999 to 2005
NC = 2006 to present
Some people use NC1 for 2006-2008 and NC2 for 2009 and newer.
Robbins is an aftermarket manufacturer that happens to make tops for our roadsters. Besides OE they're probably the best selling top in the industry.
So yeah, see if you can get help from Robbins, I bet the previous owner bought a conversion top, like I did, and didn't do the installation properly, i.e. they forgot to install those two nylon straps.
as regards the straps, hmm, i must take a look again tomorrow, i am pretty sure i saw one each side the hood.
Thanks again!
Originally the NA models had plastic windows that you would have to fold in the middle or unzip to get down.
So the straps are necessary for the later NB-style tops.
And here is the pic of the straps you had to add to the NA to use an NB-style top:
Thanks again, I have solved the problem now and the top comes down nicely.
I have to thank everyone who helped, you are a great bunch of guys!
lordelpuz (aka Keith)
Not for the faint of heart--or the impatient...
tikki01
I'm sure they use specialty threads, weather and sun resistant.
Careful using any heat source because a top that old is likely brittle and tear-prone.
Is it an original top? They usually only last 10 years or so, so it may be overdue for replacement.
You could use heat but be very, very careful. Do you have a heated garage? Maybe try stretching it 1/2" at a time, slowly.
I got glass as an upgrade. I converted it to an NB style top, so no zipper to fiddle with. I sort of regretted that - it's kind of nice to open it up but still have sun cover.
Gotta admit, though, it was pretty hard. I worked alone, but it took 2 good days. About a half day to remove the old one, and a good 5 hours or so the next day to install the new one plus convert to NB style. I told myself I'd never do it again.
Thing is, a pro install is a grand plus, and the top cost me $460. You also need a rivet gun and a good cordless drill. Search the miata.net garage for detailed instructions.
There are a couple of posts further back in this thread that might help.
ClaireS, Host
Automotive News & Views | Coupes & Convertibles
It also provides a home for vermin and insects which will damage/stain the top.
You should at least put it up if you are not going to use it for a day or so. If you use it with the top down every day, putting it up and latching it overnight a few times a week will help to prolong the life of the top.
Karl at aoksales.com
Must be incredibly hot in there...yikes.
