Jeep Grand Cherokee Limited Smartkey Problems?
Hello all,
I'm driving a 2004 Grand Cherokee Limited with approx. 95,000 miles. About two days ago I was out in the mountains and got back to my car from a hike and she would start, run for about two seconds and then stall out from what seemed to be a lack of fuel. All of my gauges were flat dead. After about two hours of messing around, I managed to get it started by spraying down the connections to the alternator with some contact cleaner. I don't know why this worked. The car ran normally to get me home.
The next day, I had to go back to that same spot to look for something I had lost (all normal getting there), and when I got back in the car and started it; it did the same thing once, then started and ran. All was fine for about five miles, and then my gauges started going haywire. They would work normally and then drop off randomly, and not in unison. Various random warning lights were going on and off. Also, my drivers side window and door locks stopped functioning at this point, but would work when the gauges were working. There were a few other bugs, such as the cruise control and steering wheel mounted stereo controls not working. I immediately went home and parked it. Upon trying to start it again, it did the same thing...started strong, ran for about two seconds, then died from what seems to be a lack of fuel.
I borrowed a code reader and got two codes which read as follows:
P1696 - No CCD/J1850 Message From TCM. "No CCD/J1850 messages received from the electronic transmission control module (EATX) or the Asian transmission controller)"
P1686 - No SKIM BUS Messages Received. "No CCD/J1850 messages received from the Smart Key Immobilizer Module (SKIM)"
The smart key system seems to be the issue. My understanding is that the anti-theft system is operated by shutting off the fuel pumps, so this makes sense. Additionally I get the icon of a key with a line through it for on the dash when trying to start the car.
What confuses me is the other issues showing up, the gauges dancing and various, seemingly unrelated electrical bugs. Could this be a result of issues with the ground strap? Could a loose ground strap be the root of all of the issues? If so, where could I find information on repairing it? My Haynes service manual is completely devoid of information on this.
Thank you for your time and input.
See Also
Wireless Control Module Fault on Jeep Grand Cherokee
See Also
Fortunately for myself the Jeep was still under warranty. I can't imagine this is cheap.
Any help would be greatly assisted. Thanks.. :confuse:
It helped me with the same problem, and solved it today.
Hope this works for you too.
Is there any way to bypass the SKIM system. Seems to me that this system is just a rip off to make Jeep owners spend large sums of money for keys, programming and additional services that would not be required otherwise.
Some bean counter must have thhought this one up to squeeze more money out of the consumer.
Mike
Having a serious SKIM issue also. Wife won't drive the JGC as seh feels it will not start when needed. Have you found a "bypass" to the SKIM?
Dana
then a week or two into it the guages all went dead, and all the dash lights came on. but the wj was still running fine. the guages would bounce on and off but usually stay on. then i realized it was happening when the temperature went below say 45 degrees. it happend alot then, but she still ran fine... the key light was coming on almost everytime but the guages seem to only bounce around when the outside temperature was under 45 degrees or so....
got to be a ground.... right??? well i undid the battery terminals and cleaned them even thought they looked good and left the battery unplugged for 20 minutes. i read this may reset the computer. did not expect much. but that was two days ago and i have not had a problem since. and the temperature was in the 30's. i am still skeptical but it is working great since i cleaned the terminals and left it unplugged to rest the computer.
so we will see
alan
4 service trips to fix a friggen' key? My first and last Jeep.
Problem started with gauges not working. Then starting/stalling issue. No a/c, windows occasionally would not work. After researching a lot of forums and blogs I tried several things. Cleaned battery terminals. Tested several modules for a short (window, MIC etc..). I had 2 problem codes, P1686 (no SKIM bus) and P1687 (no MIC bus).
The PCM is expensive. I was quoted $700.00 for a new one, not counting labor. The PCM has to be programmed to your vehicle but, this doesn't have to be done by the dealer like they want you to think. I found a company out of FL that sells refurbished and programmed PCM's. Allcomputerresorces.com. My jeep has been running fine since I replaced it a month ago. It was very easy to replace.
PS I tried to check codes with my scanner but when the faults occurred I have no power for scan tool either! Also had the battery checked and they said is was normal and holds a charge.
