Lexus ES Maintenance and Repair
in Lexus
Just had a diagnostic on "99 ES300, and the result was 5 Engine Control trouble codes (P0115 - Engine Coolant Temp Sensor 1 Circuit; P0330- Right Side Knock Sensor 2 Circuit Bank #2; P0420-Catalyst System Efficiency Below Threshold Bank #1; P0710-Transmission Fluid Temperature Sensor A Circuit).
4 ABS Codes (22,23,34&36).
2 Trac Codes (43,61.)
Mechanic says $1400 to address codes, which does NOT stop "Check Engine," "Track Off" or "ABS" Lights from blinking. Then Re-scan. Could mean replace Head Gaskets, and or Catalyst Converter, which for both price estimates are costly.
I have 135K miles. Should I sell? Is the $1400 about right? I'm in Orange County, and this is my first car that doesn't have a car note. Any suggestions, and opinions would be greatly appreciated.
Then have that code "addressed" by a trusted shop, NOT Goodyear or Firestone.
The following morning, the local Lexus checked it out and decided that the ignition switch was bad but they wouldn't have one until the next day, so we drove home and the problem didn't occur again until over five hours later and just three minutes before we arrived at home.
Our local Lexus dealer changed the ignition switch, but the failures still continued.
After four hours of searching at $100/hour they still haven't found a thing.
What could this problem be?
It might be that a connection to one of these breakers is not firmly tightened, the connection heats up accordingly and the heat helps to trip the CB..
So if that is the case, Is it necessary for me to have to even have to pay for the Mechanical Breakdown Insurance with Geico now? My new car warranty is good for some time. Not sure what to do.
I will be purchasing a 2009 ES 350 premium plus w/nav within about 2 weeks. Geico is my insurance provider and I will add Mechanical Breakdown Insurance (MBI) and also GAP which pays off any balance that is owed on your loan if your Lexus is totaled (God forbid!!). My wife has worked for Geico in customer service and glass claims for over 9 years. She recommends that you keep your Mechanical Breakdown Insurance (MBI) for several reasons. If your dealership doesn’t honor something on your warranty then MBI covers it (It doesn’t cover normal wear and tear items like tire wear, batteries, brakes, etc).
Most people aren’t aware that warranties don’t cover glass damage. A windshield on a Lexus 350 can cost about $1100.00. If you have MBI and there is only glass damage then your deductible is only $50.00 even if your comprehensive deductable is $1000.00. So this is something to consider, not trying to sell you on Geico, but just give you another angle of looking at it. Thanks
Re GAP my car is paid for so I do not have the loan or balance "owed" issue.
Considering the high reliability of Lexus cars, I think you will be fine with the warranty from Lexus. Keep in mind though, that you won't be able to get MBI after 15 months of ownership or 15k miles on the car, so that gives you a very short window to decide. You can get an after 'market warranty', but they tend to be much more than Geico's MBI. I would say if the cost of having Geico's MBI is something you can comfortably live with, then I would keep it for the peace of mind, because it will cover you long after the manufacturers warranty has ended.
Here is a great link with some additional information:
http://www.geico.com/getaquote/auto/mechanical-breakdown-faq/
NEVER...!!!
On my 2008 Lexus ES 350 the front cylinder bank plugs appear easy to remove, but the rear bank plugs are hidden.
Has anyone learned the trick to removing the rear bank plugs?
Knew I needed some fresh plugs so on one nice spring day I popped the hood and removed the engine cover in the passenger compartment. The front plugs were easy, the rear plugs were a PAIN...literally. Removed heat shields, contorted my body in ways not comfortable, left a lot of blood from my knuckles all over and 6 hours later the job was done.
The next time I took it to my local gas/service station (remember full service?).
They offered to change the plugs for $1.00 labor per plug + $1.50 each for the plugs themselves. My thought, "knock yourself out". I told them I'd come back later and they asked if I wanted to wait as it would only be 15-20 minutes.
I thought I had better stick around just for laughs. Laugh was on me. They put the van on the hoist and thru the wheel well all plugs were easily accessible. No heat shield removal, no nothing and 15 minutes later I was on my way.
Just a thought, but I wonder if the same applies to the ES.
Other states may have same law.
Mike
Thx
I need help! Thanks.
Regards...
1) TRACK OFF (FLASHING)
2) ABS (CONTINUOUSLY ON, STEADY)
3) ENGINE CHECK (CONTINUOUSLY,STEADY)
ERROR CODES P1410 , P1411 AND P0773
WHAT IS THE REMEDY.
1. Is the life of these struts only 3 years or 40,000 miles? Is there generally a warranty on struts?
2. Can bent struts cause tires to feather/warp so bad that they will cause extreme road noise especially for Lexus?
3. Can bad tires cause the mileage to drop from 25 miles/gallon to almost 13 miles/gallon?
4. If I were to change the struts, get the alignment done and buy new tires, would it fix my issue of road noise and mileage?
I want to know if you have similar experience, and if the overfilled engine oil is okay to the car. Appreciate if you could share your thought and experience,
I have to agree with you.
