GMC Jimmy Brake and ABS Problems
in GMC
can anyone tell me how to remove th power booster from my 1994 gmc jimmy...i do not know how to disconnect the rod from the break padel..
I have removed three of the four bolts from the inside..Do i have to remove the steering colum to
get to the top right bolt because i cant get to it from this angle...
I was thinking about buying my in-laws Jimmy (not sure of the year atm). But I took it for a test spin and the brakes are horrible with it.
After getting it up to about 70 on the interstate, I literally stood on the brakes and it didn't do anything.... Eventually you will slow down and come to a stop, but you really gota have some muscle to get this thing stopped.
Now I need to know what to check for this, air in the lines? or anyting specific to this issue. I dont really want my wife and future child in this vehicle, but I would really like for them to have something like this to travel in.
Let me know,
Nick
The peddle stays mushy and the dash lite stays on.
Does the ABS controller have to be reset or bled? If so, how?
The brakes do work, without activating the ABS, but the peddle travels most of the way to the floor.
The park brake is all the way up.
:sick:
The truck does have after market parts in it and I have even taken it to a GMC dealership to get their opinion and they also told me to replace the master cylinder and booster for 2500 dollars. I have already spent close to 1500 trying to fix this and I just don't want to spend 2500 to still have it not fixed!
This has been an ongoing nightmare and I just want to either fix this or get rid of this horrible truck....but i feel too guilty selling a car like this to anyone....it isn't safe.
Please help if anyone has any ideas....it has had all the lines bled. It has every other new brake part you can possible have.....it is just still weird. One guy told me it could be the something to do with the ABS but the dealership guy said that it wasn't that.
had the same issue with my s-10 the caliper's piston isnt releasing
may be able to free it up by cleaning the posts and the inner piston.
but the easiest thing to to is replace the caliper
