Rough Idle/ Front end recall
Hi. My wife has a 2005 Jeep liberty sport. The other day the check engine light came on, and the vehicle now has a rough idle. The vehicle pulls fine under normal acceleration and otherwise has always run well. We did plugs and air filter 1 month ago. Also, does anybody know the status with the front end recall?
of whats going on. If your battery is dying it can give you a rough idle. Theyll check you battery out for free, too. If you replace the battery you will have to drive about 10 miles for the computer to reset the idle.
