-June 2024 Special Lease Deals-
Mitsubishi Outlander Tire Monitoring System
bracan455
Member Posts: 5
in Mitsubishi
I just bought an aftermarket wheels not from Mitsubishi. Does anyone know how to turn off the Tire Pressure monitoring system (TPMS)? Is it worth purchasing the TPMS and having it installed on wheels. I have it on the steel rims which I am using for my Winter tires.
If you buy new sensors you have to take it to the Mitsubishi dealer for service, they will charge you $50-$100 to calibrate the vehicle to the new sensors. If you switch back to your old sensors you would need another calibration. That's *IF* the dealer has the special equipment needed to calibrate the car.
Unfortunately there is no easy way to do it.
Correct, if you change to steel wheels with no sensors you will get a TPMS warning, if you put the original sensors back on the car the computer will recognize them without needing to be recalibrated.
While the batteries are designed to last about 10 years the cost is substantial if a shop damages one and tries to get you to pay (up to $300/sensor!!!). They suggest servicing the sensor with new gaskets every time a tire is changed for an additional $8/tire and no mention about reprogramming costs.
Your government at work, NOT!!! (milking us in the name of vested interests)
BTW: the programming tool for Mitsubishi type TPMS (Bartec Tech 400) retails for $2500 each so it's hardly a "do it yourself investment" like cheap OBDII scanners at around $50. ea.
We are all commodities to be milked dry of our money. First the heath care system and now this!!!
Anyway here is the URL (may have to cut and paste into browser)
http://www.amysgarage.com/tpms_what_is_this_new_tire_pressure_monitoring_system_- all_about.shtml
PS...I only got 27,000 miles to the wear bars on the OEM Goodyear LS's...They were GOOD for a little over a year... .hence, the name.. :
Now I am in Panama (Central America) to ship the Outlander to South America and the car has 24K miles. I changed the stock tires (Goodyear 225/55R18) for Yokohama YK520 (225/55R18) after 16K miles. In Panama I got a cut (2”) on the side of the rear passenger tire that made it unusable. I took off this wheel and replaced with the “little damaged” alloy (from Edmonton) and then this annoying warning message icon “tire needs service” appeared on the information screen.
After looking for 2-weeks for an equivalent 225/55R18 I gave up (There are no tires 225/55R18 in Panama). A Mitsubishi dealer told me (In spite he is selling Outlanders with wheels 18”) that it will take 2 weeks to get me the Goodyear 225/55R18 from El Salvador. In the mean time the car was with the “little damaged” alloy from Edmonton. So I went to a Toyota dealer in Panama City and after some deliberation I agreed to buy a set of 2-tires Yokohama Geolandar G91A (Stock for the RAV V6) which is 235/55R18. I thought that after putting the new tire on the alloy that was working OK before the side cut the warning message “Tire Need Service” would go. Not at all. It is still there to my annoyance. Will somebody give some rational reasons what is going on?
Before the cut on the side of the rear tire I rotated the tires according to direction on the owner’s manual and everything was OK. It appears that if a tire manages to become fully flat this wheel/tire needs to be re-set again and because I cannot have the software and the connections for re-setting the car’s computer I am obliged to look for a Mitsubishi dealer to do the job. However, I was told in Panama that all Mitsubishi cars in this country the wheels do not have a TPMS and therefore there is no need for special software.
Is there a way to disable this TPMS for the time being until I returned to the USA? By the way the Outlander XLS V6 so far I may say the car, in spite of all the bump and speed humps along the way, is still very good.
Any help much appreciated.
I know, stupid me, we all need to be protected from ourselves and pay accordingly because of the lowest common denominator in intelligence. Oh how did we ever live without this? :P
It's one thing to slap your wrist about a fault, but another thing that the user can't reset or disable it on their own once acknowledged. (vs hunting down a Mitsu dealer to do this $$)
:confuse: :sick:
http://tirereview.com/Article/59497/selling_safety_tpms_valve_stems_and_service_- more_than_just_good_business.aspx
Vehicles from manufacture year 2007 must replace their original TPMS for a new one in the manufacturer dealership in 2013 when the TPMS ceases to be operative (battery has a life of 5-6 years). This means millions of cars. The TPMS Federal mandate has created too much controversy that there is a strong opposition to this law in the USA. There are not clear evidences that TPMS save lives just for use it.
If you want to be sure then lower one tire about 10 lbs and it should go on (I have an air compressor in the garage so it's no biggie to test and then re inflate, but otherwise you can assume it's working)
<img src=http://www.drivenautocare.com/blog/uploaded_images/tpmsdisplay1bw2-748303.jpg"
Thanx
Anna
Where did you get that information?? Currently, you are not even obligated to have TPMS functioning if you replaced either rims or tires.
TPMS is not responsible for tire flat. Change your garage (tire service) somewhere else. Check that the flat tire does not have a puncture. Replace the flat tire with the spare tire and take the flat tire (& wheel) to an experience tire service.
Do a Google search about TPMS liability.
This IS the from the law: "Based upon the above information, we now believe that there is not a sufficient basis to require vehicles to comply with FMVSS No. 138 with all replacement tires. While the number of tires expected to be incompatible with the TPMS is small, such a requirement would nonetheless raise significant practicability concerns. Because no one is certain which tires, either produced now or in the future, will cause various TPMSs to malfunction, it is not practicable to require vehicle manufacturers to certify that the TPMS will continue to function properly with all replacement tires."
In the United States, the Firestone recall in the late 1990s (which was linked to more than 100 deaths from rollovers following tire tread-separation), pushed the Clinton administration to legislate the TREAD Act. The Act mandated the use of a suitable TPMS technology in all light motor vehicles (under 10,000 pounds), to help alert drivers of severe under-inflation events. This act affects all light motor vehicles sold after September 1, 2007. Phase-in started in October 2005 at 20%, and reached 100% for models produced after September 2007. In the U.S., as of 2008 and the EU, as of November 1st 2012, all new passenger car models (M1) must be equipped with a TPMS. For N1 vehicles, TPMS are not mandatory, but if a TPMS is fitted, it must comply with the regulation.
I hope this must clear the concept.
