Volkswagen Eurovan Engine Questions
I have a 2003 VW Eurovan, every morning when I start it up the temp guage red light comes on and gives 3 short beeps, a 1/2 mile down the road it goes off and sometimes comes back on, so I stop,shut the engine off and restart which works fine for a while, I have checked the fluid levels and there are no indication of any problems. Any suggestions as to what may be wrong and why this is happening.
have you replaced yours in the last 50k miles?
might want to check that.
$20. item that could save your engine.
good luck and blessings,
I "fixed" this problem by adding just about a cup of water to reservoir.
If that doesn't do it, there are about 4 temp sensors on this vehicle, read more at the Yahoo ev_update group.
Good luck
G-12 is specifically meant for your Volkswagen - Do NOT use anything other than G-12.
Did I mention not to use anything other than G-12 in your Volkswagen....?
