2001 Acura MDX Trip Computer not working
ycmdxycmdx Member Posts: 4
edited March 2014 in Acura
Hi, I am new here and need your help. The trip computer (LCD screen) in my 2001 MDX is not working (no light/display). I tried all the buttons nearby including the brightness control. I would appreciate any suggestions. Thanks. Yifan
  • yuripyurip Member Posts: 3
    Hi Yifan:
    I've exact the same problem... What did you do?
    Yuri
  • ycmdxycmdx Member Posts: 4
    I replaced the unit with a working one I got from eBay. It works fine now. Unfortuately, the newer one is a Canadian model that shows Km, liters, etc. Good luck!
    Hmm - we may be able to help each other. I'm in Canada and just retuned from wreck yard - they have unit in US with miles and gallons + GPS but not regular one - do you want to switch?
    I do, but wondering how to complete the transaction.
  • johnessjohness Member Posts: 1
    The front fan blower on my 02 MDX quit completely. The rear blower works fine off the same switch. The fan is not bad; it hot wires ok. The fuse is not blown. I tried a used relay switch off an 00 Accord that I know is good, so I'm left thinking it's the switch, which is located in the Trip Computer. Any suggestions?
    it is likely that the trip computer has some control. my fan was back to work after i replaced it.
  • ae446cae446c Member Posts: 1
    Hi, I just bought MDX 2002 and in the middle of computer screen is a quarter size black mark-stein.This mark is from inside of the screen. Do I need buy whole new computer or I can some how fix it? Thanks for any help..
    You may want to check scrap to make it easy
