Chevy Blazer security light blinking and car won't start
stevemass5
Member Posts: 1
anyone have any idea how to reset the seurity system, turn key don;t do nothing
See also: Chevy Blazer - how to reset security
THANKS!!!
If you have any ideas on the vapor loack thing let me know!!! :sick:
Several things can cause the problem you are having, including the MAp sensor, crankshaft position sensor, any number of things. The system will only set a code if the problem is a hard failure, or repeats itself. Regarding temperature, if the temps are higher outside, the temps are higher around all those sensors used in the engine control system. Also of note is that the engine and engine compartment gets even hotter when you turn it off. There is no air or coolant flowing, and that chunk of iron just gets hotter before it starts cooling back down. Has a GM dealer checked the vehicle? Not all independents are qualified for the sophistication of an OBDII system and will just keep swapping parts until they stumble across the problem.
Put a little logic into the problem and observe closely for any other events at the time of failure, or symptoms that may seem unrelated. Just remember that the 4.3L engine and control system is in 100's of thousand of vehicles on the road and has a very good history.
The thing is, I'd rather disable the whoel thing. Anyone know how? Is it hard? If I have someoen do it, how much should it run? I'm a former toyota girl and am CLUELESS as to what to do with this!
Thanks Randy :confuse:
"Ok here is what happens to mine and please tellme if yours did the same thing. If it sits overnight and I go out to start it, it turns over but doesnt start. If i wait about 10 minute sometimes more and turn it over sometimes it will start sometimes not. It took me over an hour to get it started last week, but once it is started it will turn over everytime after that with no problems. I just want to be sure that you had the same issues before i install a remote start. Because if my problem is different it would be a waste of money. Thank you"
Hi, this is exactly what my 2001 blazer is doing. It just broke 104k miles. I am a college student and can not afford to fix alot of things that may or may not be wrong with it. Mine came with a remote started. Did you ever figure this out? If you did you would be helping me out a Ton!! Some have said they think it is the distributor cap, but I have no idea. Please let me know, thank you.
Randi
Honest mechanics are hard to find these days. An auto repair shop with honest mechanics are usually bankrupt within the first five years of opening business.
First thing is to clean your battery terminals and make sure that the battery is good. If the battery is good then 70% of the time it's the ICM (ignition control module). You may be getting spark but the ICM controls your spark and injector. Check for an injector pulse.
I've also seen no security light flashing but was indeed the security causing the problem.
There is a way to bypass the security and a ton of YouTube videos to show you how, this is why one guys Blazer started after a remote start was put in, it bypassed the security system.
