Mazda above 100K Miles
                    I am considering buying a used Mazda MPV 2002 MY which has about 100K miles. What have other owners experienced at such high miles..
I am very glad I got the warranty. Over the past two years, I've had the ignition coils on the 3 back cylinders fail (covered), the fuel sending module fail (covered), and just last week the winch for the spare tire failed (covered). I've also had some normal maintenance, e.g. I had the 60k service including a tranny flush, and I had to replace the front brake pads. Plus oil changes, filters etc. I have already recouped my cost on the warranty. And I still have nearly 3 years to go! With what I've read about tranny failures on the 2002+ MPVs with the 5AT, I am really glad I have the warranty. I plan on selling the van just before the warranty expires. I won't need a van any more then--will have only one child at home then.
So my advice is, try to get the repair and maintenance history on the van, and (especially if a part hasn't been replaced already), expect that any part can fail at any time on a van with 100k miles.
P.S. I've also noticed rust starting at the inside lower edges of the front doors, where a lot of salt gets thrown up by the wheels in winter (I live in MN). Something to check for on a van with so many miles. Check that the spare tire winch works, also! The part cost nearly $500!
I had to replace #5 (front) coil recently, still under warranty. If one back coil had failed I would have had all back 3 replaced as there is a lot of labor involved (1.5 hours book time), and it would have been cheaper to have them replaced all at once, than individually as they broke down.
I wanted to know more on the details on the extended warranty. i am shopping for one as my MPV is 2003.
let me know
Sun
so i bought a mazda 323 couple of weeks ago....evenntually it has a problem!!!
it doesnt start so easily and sometimes doent start at ol.....i got it checked ....checked out evrithing,plugs,,fuel pump,injecter....it doesnt work....i need this car to go to work but if it doesnt start at the ryt tym i would b in one hell of trouble......its a mazda astina 1989....sometyms it starts easily....kind of has a mind of it own......
can nyone out there help me out......
did you find out of the problem. I have just the same problem.
Have been 3 time to the local Mazda Dealer and their computer hook up can not find the problem. Have change air and oil filter. He still turn off very often the first 30 min.
after starting. My Mazda MPV is diesel.
Also; oil leaks - anyone have problems with leading oil on the back side of the engine? I can't pin point it to where it is coming from.
I love the basics of the vehicle but besides the tranny issues early on - why there is no on off overall interior light switch I'll never know. You can turn on the little ones by the mirror or the little one on the tailgate, but no main switch to turn them on after the timer shuts them off!! Annoying! Heat is always another issue. Takes forever to heat up - always has since new and they could never fix it.
Thanks for listening and do reply with ideas or experiences. :confuse:
Not sure if that is your problem. Good Luck
I have a 97 Mazda MPV purchased it used and it too leaks oil and trouble with the catalytic converter. I am due for inspection soon and don't went to put a lot of money into the car. My husband wants to put a hole in and try and drain or something crazy like that. Please help if you have any ideas. My engine light is on with the same code (catalytic converter) I tried some gas treatment - didn't work.
Anyway - thanks for your help
Mary
I found your post because I just purchased a very nicely kept 2002 MPV with only 53000 miles but have read so much about the transmission problems. So, I am considering buying an extended warranty - either the one from the dealer or go on my own. But , I've also read stories about these warranties not being worth it for the big stuff. Please tell me, if you remember or have the info - what is the name of the company and the name of the policy coverage that you bought.
thank you very much.
Also, if anyone out there has had a good experience with having to utilize an extended warranty, please tell me your companies.
Sounds like you may have at true catalytic issue with loss of power or you have the coil issues that can be from water getting into the spark plug wells and shorting out. New coils/caps do not have the pooling problem of water on the top as the originals had. They can crack and water seeps into the plug wells. Good luck! They are a problem riddled unit and have been for most the 2000-2004 years. Things improved from 2004-06.
I has had a problem with my Mazda MPV 2002 diesel, that the engine stopped when I was driving, I have change the "magnet ventil" on the oil pump, and now
it is OK. It is easy to change, you can do it self.
