Mazda CX-9 Driver Information System (DIS)
                    I've unlocked the DIS on my 3 but can't get the CX9 to fully display.  In the 3, you push the FM/AM and CD buttons together, insert the key and turn to "ON."  Hold the buttons until "DIS ON" displays, then hold the SET (or :00) button until the clock changes over to the DIS.
My wife's 2008 Sport AWD (with Bose) acts the same way to get the "DIS ON" message, but it has neither a SET or :00 button, so I don't know which button to use. To complicate it further, sometimes people have had to reset their battery or turn they car off then back on after first getting DIS ON.
Anyone try this? Anyone want to experiment to find the right combination of buttons? FYI, the DIS can display real-time MPG, average MPG, DTE and average MPH.
I have skimmed thru the workshop manual and don't remember reading anything related to DIS mentioned in the phonebook-thick workshop manual. Yes, there is a diagnostic mode and test mode that one can enter thru a bunch of steps. However, I have no seen anything related to MPG at all.
When I get back tonight, I will dig thru the workshop manual again to see if there is any mentioning of this procedure. Usually, a workshop manual will cover things like that so that service technician would know how to.
I have a Prius. I love to monitor MPG while I drive. It trains you to be a better driver, MPG-wise.
I am considering ScanGuageII ($159). It provides much more than just MPG.
Read it up and decide for yourself.
Now that we found a way to unlock it we just need to figure out how to access it.
we have it in the middle east, i own CX9 GT and we do have an Info button next to the clock button, it shows all trip infos + MPGs
i figured out that Autsralia's mazda's also have this button..
Mine doesn't have a clock button. Is it on the center console surrounding the LCD display?
Click on the INTERIOR View and the image of the LCD on the 2nd Row, first on the left on the Mazda USA website right here....
http://www.mazdausa.com/MusaWeb/displayPage.action?pageParameter=modelsGallery&v- ehicleCode=CX9
Is your button here? Are your buttons labeled differently? Do you have SAT? RTN, DISP?
Something really strange going on here. Can you upload a photo of where on yoru dash this button is on YOUR CX-9?
The OZ model has the following buttons
LEFT of LCD Display
- Load/Eject
-Clock
- H (our I assume)
- M (inute I assume)
- Disp
- SCAN
On the Right the OZ CX-9 has
-Tune/Seek/Track
- FM1/2
- AM
- CD
- Media
For us here in the U.S. we have the following buttons
LEFT of LCD Display
Load/Eject
Navi
Menu
RTN (Return)
Disp
Audio
Scan
On the RIGHT we have
Tune/Seek/Track
FM/AM
SAT
CD
Media
So my question to those down under is how do you navigate in and out of the navigation system without the Return button? How do you get into NAvigation without the NAV button?? You must have more touchscreen options in your menu than in ours.
We CANNOT set the time because the manul says that it's automatically set by the GPS system.
So why would Mazda do this???
"Unfortunately this is only available for new vehicles and cannot be adapted to older models. Also, the data management system that controls the information system is factory installed and cannot be installed at the dealership."
Believe what you will, but I think it might be time to abandon this quest and install the ScanGuage II.
That's like going to the IRS and asking what loophole you should use when filing your taxes.
You get much more than just a trip computer. It has the "Scan", "Gauge" functions that a "Trip" computer from factory does not offer.
Scan: see error codes, and look it up on internet for causes of problems (knock on the wood)
Gauge: see detail parameters of your powertrain such as coolant temp, battery voltage (knowing when your battery is dying..) and all sorts of details.
Trip: current, today, previous day, this tank, distance, fuel consumed, ....
I mounted to in front of the instrument cluster and behind the steering wheel. The cable is almost invisible since the OBDII connector is right below the steering wheel column. It looks like part of the instrumentation.
I'd love to see a picture of your SG mounted in front of the instrument cluster, if you have time. I'm still debating over trying that location, or purchasing a BlendMount and putting it over the rearview mirror.
I can't put it on the rearview mirror since I got a auto-dimming homelink one. The space on top of it seems very limited to me. Besides, it is natural to me to put all
driving parameters in one place.
My ScanGaugeII is blocking the odometer and trip meter a bit, but one can still see them if one leans forward. So, no problem there. I don't try to read the odometer/trip meter all the time. ScanGaugeII info is more interesting to me.
Here's the link for anyone looking for the CarSpace page:
http://www.carspace.com/ceric
