momentary engin loss under acceleration
2006 300 C AWD 37000 miles.
Engine stops during acceleration.
Under acceleration engine dies for a very very brief moment, you will hear one or two ding dings ( bell ) no check engine light or codes. Looking for ideas as to cause and corrective action.
Under acceleration engine dies for a very very brief moment, you will hear one or two ding dings ( bell ) no check engine light or codes. Looking for ideas as to cause and corrective action." "I use the recommended mid range. It almost seems that it is a momentary power loss. It is not consistant at any one speed,it can happen at any speed, under acceleration. I have checked the ground terminals as well as all plug ins. Again, no code which leads me to power loss. This car is a Hemi V 8 with variable piston ignition, 4 cylinder or 8 cylinder. I wonder if the momentary loss can be created when the engine is moveing from one mode to another."
What you are describing is not the normal function of the MDS (cylinder deactivation) which is never apparent to the driver (not described by others and certainly I haven't noticed in 43,000 miles of driving). The fact that a bell is ringing makes me think that the computer is being told something, but I agree, there should be a code. I take it you have had it scanned.
Most notably in cold weather ( winter ) vs summer.
