Jaguar - Denso Navigation System Problems
I have a 2002 Jaguar X-TYPE with the Denso Navigation System. Earlier in the year the system stopped reading the Navigation disc that came with the car giving the Error "This is not a MAP DVD"
In an effort to get the Navigation portion working for a business trip, I performed a disc copy of the original to a DVD+RW disc. The system still didn't work. That's when I did a stupid thing...
I inputted the diagnostic code into the head unit and tried to do a software update from the original disc. It attempted the update but erred saying it couldn't find the firmware file.
Since then the screed is completely dead. The air climate control is in some sort of default mode defogging the windshield. The LCD status window below the screen flashes "C" the "50" then "51".
I have tried swapping out the Nav/Audio/Climate screen assembly in the cabin AND left the positive lead off the car overnight. To my surprise neither action worked.
Here are my questions:
1. Where is the physical location of the firmware for this system is it in the display unit or in the trunk?
2. Is there a diagnostic sequence to turn on or unlock the navigation system.
3. What are the tried solutions (and their associated costs) to this
problem?
My thanks to you in advance.
Bob
problem?
Bob
I have the same problem as you, did you manage to resolve this issue.
I've been told to replace the NAV control module head unit located in the trunk compartment on the left above the disc changer... haven't found any after party manufacturer to sell this piece other then dealership for $4000. The car is hardly worth that. I wouldn't care if I could figure out a way to control the cliamate controls with out the nav unit... Please let me know if any developments made!
So far, I can tell that the climate control unit goes into a default mode (air on when hot outside heater on when cold outside) vented out the defrost ports, so it has been usable. From a system standpoint I an relatively certain my trunk unit problem lies in the DVD-ROM drive. But I am not sure how to address the issue.
I am opting to throw away this system, and replace it with a double din 7" navigation stereo that has AM/FM/DVD/SD/MP3 capabilities coupled with a dedicated digital climate control panel (you have to use a digital one).
I have installed the panel this past weekend, by mounting it in the navigation system frame and connecting the two cables from the ACU, located in the passenger's footwell area. I get heartbeat it displays outside and thrermostat setting temperatures. The blower unit can be controlled, and I can turn from all heat to all air. Unfortunately I cannot change the heat output (its either hottest or coldest depending on temperature setting), nor can I enable the rear defroster, or change where the air blows (although the LCD indicates what I select). I will continue to work the problem in my spare time then post with a resolution.
In the interim if anyone has questions, please put an email address in the post so when it is forwarded I may contact you directly.
Bob Dimond
Did the Dealer tell you that it is the unit in the truck? The Dealer didn't say (Navigation Control Module) but I assumed it was the unit in the dash. However, I have no power at the unit in the truck. Now I am second guessing.
I agree, if I only could get the climate control to work I would be happy. I will keep you posted on any new development.
I too researched salvage parts, I have found Ebay sometimes works- right now (which sparked my most recent searches) there is a nav module and screen set up for $1400 on Ebay for the x type... It may be an option. $1400 is a lot of cash though when the car values are plummitting.
How much was the third party system in previous post? That seems like an alternative.
It's hard to put money in. We hardly ever drive the it, we have another primary vehicle (a nissan- I highly recommend
Or better yet, further conversation could be had right here where lots of people will benefit now and in the future.
My Navigation Control Unit was trashed. A new replacement was at a ridiculous price, with used units on Ebay very hard to find and still expensive. After reviewing wiring diagrams, I had replaced the all in one control screed with a dedicated digital climate control panel and hooked the two wiring harnesses from the remote Air Conditioning Control Module) (A/CCM), which is located in the front passengers (US) foot well, and connected then to the climate control panel which has a built in A/CCM.
I was able to get the blower output working but not the rear defrost, air temperature output, or air location output to change. I called the a Jaguar dealer in Columbus Ohio and told them what I had done, and asked for help and all they said is you can't retrofit a standard digital climate control panel in a car that has factory navigation, the wiring is different.
WRONG!
The solution to this problem was a different digital Climate control panel. The Climate control panel I had was for the electrically heated windscreen and was not compatible with my car. With the other unit (Used $50.00 US) I now have all climate functions!!!
In addition I did find a cheap Navigation Control Unit so I have the factory system working right now. But still looking to replace it when the weather improves.
So to recap: If you're looking to replace your factory all-in-one system, don't seek the advice of some ill informed dealer crony who doesn't know crap.
You CAN replace the all-in-one unit with just an after-market radio, wiring harness (for the radio), bezel and of course the RIGHT climate control unit which simply utilizes the two wiring harnesses that go into that go into the remote A/CCM located down by the passengers (US) foot well.
So instead of paying $4400 for a new unit, you can buy a NEW 7" double-din (GPS, Radio, DVD, MP3) player, a wiring harness from the jag to the radio (or you can just cut the jag plug off and wire in the radio harness directly) an x-type double-din bezel plate (to make it look like a factory install), and a used DIGITAL climate control panel.
The cost:
About $500 and you INCREASE the functionality over the factory GPS with DVD, MP3, and possible inputs for a backup camera. In addition the maps are more recent and more readily upgradeable.
And if you live need help, I'm an email away. And if you live in the Cleveland Ohio area drive to Lakewood and I'll even help you in person.
Merry Christmas!!!
Bob Dimond
Ray
Thanks again to all the bloggers who post their problems to help everyone out.
Much appreciation.
IF YOUR WILLING TO SPEND SOME MONEY THROUGH TRAIL AND ERROR AND TEAR INTO YOUR CAR:
The non-Navigation X-types have two units that occupy the same space as the console and radio. The complete assembly has two LCD screens. The top screen, just below your hazzard switch, is the climate control panel.
If you find the right climate control unit (MUST be digital and must match the windscreen option of your car so I cannot tell anyone specifically what they need) IT WILL WORK IN PLACE OF THE CENTER AND TRUNK NAVIGATION PIECES FOR MY CAR. Once again I have detailed this process in my "UPDATE" and "FINAL UPDATE" posts so I WILL NOT waste my time and reiterate it here.
As for what parts to obtain to convert from the factory navigation system:
Do a search on ebay category "all of e-bay motors" for the words "x-type" and "climate" then select "car & truck parts and accessories" for the climate control unit. 9 hits (2 auction 7 e-bay store). I reccommend ebay items sold by LKQONLINE as they tend to supply information like VIN number series and option list.
Do a search on e-bay category "all of ebay motors" for the words "double din" , "GPS" "SD" and "DVD" The select "Car Audio & Electronics" This should return dozens of hits for a 6-7" screen unit that will fit in the jag. Select the location and featres you want. READ THE FINE PRINT to make sure the unit has a GPS included versus things like "GPS ready" which means a separate GPS unit (usually not included) can be added on. One unit that could serve as a factry GPS replacement (if you want to Narrow it down to a name brand you can see at best buy) woud be a Pioneer AVIC-900BT.
Lok here for the fascia plate so it looks like a factory installation:
http://www.sonicelectronix.com/item_13402_Metra+99-9500.html#
Then you need to the x-type plug off and wire in your new radio wiring harness or purchase an adapter:
http://www.dynamicsounds.co.uk/jaguar-xtype-wiring-adaptor-autoleads-pc2814-p-26- 84.html
NOTE: This is as specific as I can get. The radio harness should be standard accross all models, but the climate control wiring harness *MAY* differ between year to year and vehicle feature set. For example, I purchased a dedicated climate control unit that did not work (excet for the blower controls, this was mentioned in my update). The reason? The unit and wiring harness were not compatible. The unit I purchased was for a x-type with a heated windshield (windscreen). When I purchased a non-heated windsheild unit, EVERYTHING WORKED. So you see, I can't answer the specifics BECAUSE I DON'T OWN YOUR CAR. Check with your dealer for your car's options, and read the ebay descriptions for VIN series and options the climate control unit supports. Check wiring diagrams. I was able figure out how to fit a dedicated climate control unit into my naviagion equiped x-type because I was willing to invest A LOT of my time scouring the internet and LOOSE a little money to succeed. There are no surefire easy "cookbok" instructions. Even the Cleveland or Columbus Jaguar dealership "experts" did not think what I accomplished could be done.
If my Nav system bites the dust again, I will replace it with an aftermarket unit and I will photograph a detailed procedure and post.
Short of another nav system failure, what I can do get your email address. From there I will email my number and we can discuss your options over the phone. If anyone lives in my area (Lakewood, Ohio) they can make arrangements to come to me, and I will show them the components and how to migrate from the NAV system climate control to a dedicated unit. Weather permitting I will even see if one of the two climate control units I have purchased will work with your car.
This is all I can do, so please don't ask for more "details".
Bob
I am in columbus, my email is sarahcgaylor@yahoo.com.
Thanks again.
I checked for them on ebay religiously. Never found one that I could afford to get, just to get it back to where it was, when I wanted something better anyway. When I found this thread, I thought, no way that could work. Did some more research, and finally bit the bullet and ordred this off of ebay. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=190319526050&viewi- tem=&sspagename=STRK%3AMEWNX%3AIT
I do have an 02, but it works, and works great. As the original author posted, you have to disconnect the plugs from the passenger footwell and pull those up to where the climate control mounts.
The installation was easy, then again I have done numerous car stereo installations, and honestly, it was along the same lines, but easier.
The bad part, I HAVE to get an aftermarker stereo. The touch screen is seperate, you will still have the same functionality from your stereo as you did with the dead touch screen, but now there is a hole in my dash.
At this point, I don't care, it works and I can drive around today in 97 degree heat and use my A/C.
I will now open up the floor to questions...
I realize this reply is almost a year after your post, but I am hoping you will find it and be able to help. I live near the Cleveland area and have been experiencing the same issues with my Navigation screen going blank and the climate control being unavailable. I tried doing a hard reset by disconnecting the battery but that did not work. I have an appointment with the dealer in about a week and am anticipating them telling me I need to replace the module at an astronomical cost.
please send me an email at Jag02X(at)yahoo(dot)com if you are willing to offer some assistance. Thanks in advance.
Many thanks
First off, I have a 2002 x-type that was experiencing all the same issues being mentioned - touch screen went black, climate control did not work, just blowing full air through the defrost, etc. As several people have mentioned, the repair for this issue is to replace the Navigation module (which is basically the DVD-ROM drive in the trunk sitting on top of your CD changer). The dealer wants several thousand dollars for a new one. I was able to find a handful of used ones available on eBay (in Dec 09) through the seller "lkqonline" by searching for "x type navigation". The listings are very detailed and give you part numbers and VIN #'s that the part should work with. The jaguar part # listed for my drive was 2R83-10E887-AA, but I think jaguar may have renumbered this same part in newer models (as I said, I have a 2002). The unit cost me about $350, which is significantly cheaper than the dealer option.
Installing the new DVD drive was simple. I had to first pull back the felt liner around the inside of the trunk that goes around the DVD/CD drives to gain access to the harness holding the drives. There are a handful of screws that need to be removed (I think I also needed a small wrench for a couple of bolts) so that you can loosen the DVD drive and access the wiring behind it. There were about five wires total that had to be unplugged (one is the GPS cable). There wasn't a lot of slack to pull the drive out and get behind it, but it wasn't too difficult. After the old drive was removed, I just plugged the wires into the new drive, reconnected it to the harness and started the car and magic, the screen came back to life and the climate control system was fully functional! The unit off of eBay did not come with a maps DVD, so it did prompt me to load the disk, which I had already removed from my original drive, so I just inserted that one into the new drive and the GPS booted up and my navigation was up and functioning.
I am not very technical when it comes to working with cars and I was shocked at how easy it was to fix. Hopefully this same solution will work for the majority of people who are experiencing the same issues. I don't know if the newer models of the x-type would require any different parts, but like I said mine is a 2002 and the part on eBay stated which VIN #'s the part would work with.
If you have any non-technical questions about my experience I can try to offer some answers.
Good luck!
Andy
You post is too vague.
If your replacing you faulty nav computer, just replace the nav module located in the trunk, you don't need anything else. If that doesn't work you can try the touchscreen although I doubt that is the problem.
If your talking about outfitting an X-Type that did not come with a navigation system from the factory then, in my opinion, you are HEADING DOWN THE WRONG PATH! Search the threads as there are people who have done this, but in order to oufit a non-nav X-Type with factory navigation equipment you need:
The touchscreen console.
The navigation computer.
The remote climate control module
A Wiring harness from the console to the trunk.
The GPS antenna
My guess is installing the harness will be difficult to obtain and difficult to install. The remote climate control is a little difficult to install. The GPS antenna might be difficult to install.
If you're thinking of a installing a GPS in a non nav Jag just get a double DIN radio with GPS capability, wire it into the stereo harness and be done with it. I've mentioned this in my solution for transitioning a nav-equipped jaguar to standard climate controls.
While the display screen will be slightly smaller, the maps will be more recent and easier to update. The unit will have have at least MP3 capability, and possibly a host of other features such as DVD, rear view camera, aux audio/video input, USB, SD card, or even bluetooth.
These units sell on ebay for under $500 and will be MUCH easier to install and are
more futureproof that what the luddites at Jaguar and Denso would sell you.
Hope this helps,
Bob
I am using the correct 'Whereis' nav disc for my region which is New Zealand.
My problem is street names do not show up plus the intended destination address cannot be entered.
I have been told by a dealer here in NZ that I have to replace the
DVD Rom unit in the boot of the car with a modified one and the disc will then work perfectly.
He wants $3400.00 for a unit which is away out of my league.
Can some kind person tell me what the modifcation would be or perhaps it's an after market unit.
Rex.
Is your X Type a Japanese import by any chance? I am also in NZ and have just bought a 2004 XJ and have a similar issue with my sat nav although I have been playing with a DVD from a US Ford so wondered if it just wasn't compatible. I have got a copy of a genuine Jaguar UK DVD being sent to me to try out but it sounds like that won't work either.
Is your DVD a genuine Jaguar one? If so where did you get it from?
Regards
Richard
Like a few of you guys here, the DVD-Nav player in the trunk died a few months ago but it's becoming a problem now that summer in Texas is in full swing. The model number for my part is 2R83 10E887 AB. I was wondering if the AA on the 2002 Jag or even later models like the AF of the same part would work in my car. I've been checking ebay almost daily for the past few weeks and going around to salvage yards and nobody seems to have this one part. Like Bob mentioned, LKQOnline on ebay seems to be a solid source of parts for this increasingly troublesome car so thanks for that! I'd appreciate any advice or experiences anyone could share on this topic.
Many thanks,
James
1. what about if i get an entire working Nav unit removed from a Dead jag xj X308 (1997–2003) or X350 (2003-2007) they all seem to have a Nav unit. do you think the dimension of the xj Nav console can fit into a Xtpye dash board panel. are the radio a/c console etc..dimensions of the XJ and the x-type similar? they look similarand a like
2. kindly recommend the model number of the double DIN radio with GPS capability that will fit exactly into the xType dash boards.
Expound below.
http://usnews.rankingsandreviews.com/cars-trucks/Jaguar_X-Type/photos-interior/s- - tereo-controls/
The result I want is to have a professionally installed, reliable, "integrated" type of system. Does anyone have the specialized knowledge needed to do that kind of an upgrade, or tell me what the alternatives might be?
Michael St.James
MODERATOR /ADMINISTRATOR
Review your vehicle
Is it the wrong disc bearing in mind that mine is a cd and not a dvd. or is it that my cd unit is knackered?
i also think its a Denso but i maybe wrong.
Any help would be great. many thanks.
Dave
http://www.jaguarforum.co.uk/viewtopic.php?f=13&t=47737#p432267
