Grand Prix 2001 No power to climate control then sometimes it just starts
Just purchased car. Climate controls don't work and then rendomly start working. I replaced the fan resistor and when it does have power it works for all settings, but sometimes when I turn it on it just doesn't get power. Then 5 or 10 minutes later it will get power and just start working. When it is running it seems like every setting works fine. When it's not getting power I can't get any of the options to work.
Anyone have any ideas? Is it possible the control panel is bad? I was going to take the dash panel off to check for loose connections, but wanted to check online before taking things apart.
Thanks for any help you can provide.
