Nissan Altima Hybrid Battery/Electric Motor Questions
How long should the hybrid battery be able to power the electric motor in bumper-to-bumper traffic? My NAH is running great....has 6000 miles and I've been getting 35-36 MPG on every tank of gas. But, I've been stuck in traffic twice and both times the battery meter went down very quickly (less than 5 minutes), the EV mode stopped and the engine turned on. After 5 minutes, the EV mode went back on, but then went off again after a few minutes. Is this normal? I find it very annoying to think about burning gas when I have an electric motor available.
If cruise control is engaged, stepping on the brake pedal engages the mechanical brakes but not regenerative braking (i.e., no charging on the Power Meter). This is 100% reproducible and is true no matter what the charge level is on the high voltage batteries.
Obviously, this negatively impacts mileage unless I do not use the cruise control at all. Nissan service folks, largely being incompetent in my experience, don't appear to even grasp the issue
Has anybody else experienced this? Is this a generic NAH problem or specific only to my car?
Set the CC for 40 mph and step on the brakes moderately. The "power meter" will NEVER dip into the blue (indicating regenerative braking) UNLESS you remove your foot entirely from the brake pedal and reapply the brakes. This time, the computer sees the CC as "off" from the first brake push, and regenerative braking works as it should.
The "Shop Foreman" at my local Nissan deal "has heard this problem many times before", but they won't do anything because it doesn't show an error code, and, therefore, "was working as designed". I asked if an error code would show if the right front wheel fell off. The service person admitted it would not. So I asked if that would mean it was "was working as designed".
This is excatly how it is supposed to work. What is happening is that the power from the engine is being sent to the battery instead of the drivetrain. Turn on you monitor to see this. If you go down a very long grade (1 mile or more) you should be able to move your battery capacity to the top of the range.
I have a 2007 NAH with 40000, I thought the electric motor makes too much noise recently (around 3 months) - I'm sure the ICE was not running - when I do my "ear test".
Does anyone feel the same way about the noise from the electric motor?
Does the electric motor require any "scheduled" maintenance?
