When to replace radiator hoses on a 2002 Town and Country minivan
Does anyone know the recommended mileage when the radiator hoses have to be replaced. I have 118,000 miles on my minivan now with the original hoses. Never had a problem with the heating system with the exception of having to replace the rear heater lines.
Steve
Steve
You do NOT want the timing belt to break on you. And there are no obvious clues that it is going to break. Since the water pump is located so close to the timing belt, it should be replaced, too.
Have you done a coolant change-out yet? If not, it's time for that too, and would be the ideal time to replace the hoses.
Me, I usually don't replace hoses until they look like they're ready to split, which you can sometimes tell just by feeling the hoses, particularly where they make bends. Or, I wait for a small leak to develop, which usually shows up around one of the clamps.
I did go out and have the hoses replaced. And the coolant. Now that you mentioned it, I have to look into having the timing belt replaced. Any body have any experience with this item? Is it a costly procedure?
Again, many thanks,
Steve
BTW, you never said what type of engine you have.
The engine is the 3.8L version.
Thanks, Steve
https://www.rockauto.com/catalog/x,carcode,1384501,pgname,Engine
If you click on the (safe) link above and then find the Timing Chain, you will see said chain.
-Flush the cooling system and replace the antifreeze.
-Replace the Serpentine Belt.
https://www.rockauto.com/catalog/x,carcode,1384501,parttype,8905
-Inspect the Serpentine Belt Tensioner and replace as needed
https://www.rockauto.com/catalog/x,carcode,1384501,parttype,11659
-Replace the upper and lower radiator hoses
https://www.rockauto.com/catalog/x,carcode,1384501,parttype,2058
https://www.rockauto.com/catalog/x,carcode,1384501,parttype,2057
-Replace Thermostat
https://www.rockauto.com/catalog/x,carcode,1384501,parttype,2200
Consider replacing water pump
https://www.rockauto.com/catalog/x,carcode,1384501,parttype,2208
Consider changing Transmission filter (and as much transmission fluid as you can)
https://www.rockauto.com/catalog/x,carcode,1384501,parttype,8600
Have brake pads and rotors inspected
Have the CV boots inspected for cracks/grease leaks.
I do this level of repair on my own, so I can't help with repair / labor costs. But I recommend you sign up for http://repairpal.com/ and you can track your service and get pricing too.
Good Luck!
Then you can tip that side of the engine up by slowly raising the floor jack until you have enough room between the engine and fender to get your hands in there to work with wrenches.
I have done many repairs & replacements on these engines this way. When you are finished, you may need a 3 to 4 foot length of pipe or suitable type of pry bar to jiggle the engine back toward the passenger side for proper alignment of the motor mounts to get them & the engine back into proper position to re-bolt the mounts.
On my 2002 T/C Limited there belt tensioner has both a square opening and a stub on it. The stub is 19mm / 3/4 inch and can be accessed from below with a combination wrench to loosen the tensioner. The forward splash shield needs to be removed; jack up the car, put a jack stand under it, and then remove the passenger tire and wheel - now you can get to the splash shield - three zip fasteners and one 10mm bolt to the forward frame held mine in place. The tensioner requires a bit of force but I was able to do it. Putting the belt on is a lot easier if you have a buddy help you - one person loosens the tensioner, the other sllips the belt off of the forward lower pulley. Hope this helps anyone who finds it.
