Lexus RX 300 Check Engine, VSC and TRAC OFF Lights
Just had some work done on my 2003 RX300. air filter, new water pump, timing belft front end alingment, rear breaks, turn rotor, caliper service rear dffy fluid, cabin air filter. Now as I drive it home the VSC light comes on and the repair shop tells me nothing to worry about bring it back tomorrow there is some sort of fluid leak. What do you think?
See also: Troubleshooting Lexus RX 300 Check Engine & VSC
No real problem as I soon had tire chains on all four.
Last week I contacted the service advisor at Lexus of Bellevue who proceeded to advise me, profusely, that the VSC/Trac system will always be operational unless an indicator is lit on the instrument panel indicating otherwise. When I persisted he insisted that it was probably working and I wasn't familier enough with its actions to know.
So I fired off an email to customer_satisfaction_inquiries@lexus.com.
In response I was told to contact a dealer.
Over the weekend I got out the shop manuals and discovered that the ABS was indicating codes 31,32, and 33, apparently a temporary or intermittent failure of both front wheel speed sensors and one rear wheel sensor, and VSC was indicating a code of 43, ABS control failure.
According to the manual the ABS will continue to work with these codes but it was unclear, undefined, as to what the result would be with the VSC code 43.
So I contacted Lexus of Seattle and after a long discussion I was told that a VSC code 43 would result in the VSC/Trac system being non-functional but that there should have been a VSC failure indication on the instrument panel. The Lexus Lexus technician suggested that I might have inadvertently ignored the failure indication for enough drive cycles that it would have extinguished.
I'm quite sure, VERY sure, there was never an indication of VSC or Trac failure on my instrument panel for multiple drive cycles. When I suggested that the firmware might be flawed in that no indication was displayed the technician allowed that the 2001 was the first year of VSC/Trac implementation on the RX series but refused to speculate further.
He did tell me that the wheel speed sensor faults could result from ordinary wheelspin that occurs in low traction conditions.
So I have cleared the fault codes but have not yet been able to test the VSC/trac system for operational capability.
Also, I am looking to replace the strip that is on the bumper. It says Lexus on it. I believe it is there to protect the paint from any damage when moving stuff in or out of the trunk area. Some how, mine has vanished... Anyone know where I can get a replacement?
I have same problem with my toyta Highlander 03 . I clear code 3 times. replace sensors. still same issue.
anyone with similer problems who got is fix. please help.
thank you
Today the light just magically went off... ironically after my son put gas in the car and didn't turn the car off while pumping. Coincidence?!
Did you by chance mean to say the CEL AND VSC came on..??
If CEL came on then VSC is a simple default condition with any CEL indication.
If no CEL and only VSC then there are only two components unique to VSC, the yaw sensor and the stearing wheel rotational position sensor.
Ortmann1 :sick:
Stearing wheel off-center..??
Do not trust the STEALERSHIPS!! I can't stress that enough :sick: .
I was on the way to drop off my wife's car to the STEALERSHIP and just before leaving I googled the problem and bam, there was the answer.
Reconnected the hose and disconnected the battery for 15 minutes. Problem solved
thanks.
Right after I got it back from putting in new engine (due to oil sludge,I now learn) the Check engine and trac off lights came on.
Brought car back and
I had dealership check the code for these two lights being on &
the code says to replace solenoid for tranny ($600-$1000),
maybe the air filter hose has been disconnected.
AS THE ONES I GOT ARE IN CHINESE? AND I DO NOT NO WHAT TO DO
MY EMAIL IS GARRYDARCY@HOTMAIL.COM
AND I RESIDE IN MELBOURNE AUSTRALIA
MANY THANKS
SUVs and Smart Shopper
Not sure just voicing an opinion
Get thee to a welding shop and have them use a gas cutting torch to HEAT the manifold while avoiding heating the O2 sensor, then remove the "fused" sensor.
Has anyone had this problem with the VSC and TRAC OFF lights???
AND . . . . consequently, we unplugged the battery (as suggested) . . . . replugged . . . . the lights came back on once . . . . then, not again . . . . BUT, SINCE REPLUGGING, the electronic data on the dash has been inaccurate (i.e., 25 mpg)!!! Anyway, no manual!
Has anyone had this (2nd) problem with unplugging the battery and electronic data display???
Any help would be GREATLY appreciated. Thanks in advance.
Now I bought 2007 highlander.. I have 45K miles on it.. same problem.. P031.. O2 sensor.. shopping for cheaper replacement.. if I don't get it.. wait till emission test fails..
Rao
Do you use any cleaning product for the system?
It was warranteed at least until 70,000 for emission-related items, wasn't it (U.S. vehicles)? Why not have the EFI cleaned or the defective part replaced?
I wouldn't use a cheaper third-party sensor. You can see the difference when you have both side-by-side.
Other RX300's tend to need cleaning of MAF sensor and the idle servo (really easy DIY and lots of tips using "search" on this and other sites) long before O2, but those have different codes.
I hope the info helps. I'm really surprised your OEM O2 sensor didn't last very long, and it happened twice.
I solved my initial occurrence by reconnecting the hose behind the air filter cover. But a year later, the same lights came on. Refilling the gas tank, tightening the gas cap, and resetting the lights by disconnecting the battery for 15 minutes did the trick...
CE can be something much more serious.
HELP
Gale
Eli
After clearing, it seems to come on after driving an hour or two upon moderate (1/2-2/3 throttle) acceleration (freeway onramp uphill, etc.). Upon restart CEL remains on.
I'm taking it to my neighbor Toyota dealer and asking for sparkplug replacement, oil change and read the trouble codes again. Is the dealer going to say I also need new expensive oxygen sensors?
Does anyone know the locations for each sensor?
How many O2 sensors are there?
I've done O2 sensors, etc. on other cars before, and have no problem with investing in it so it's running right. I just want to be prepared, because if it's a set of sensors I can replace myself, I'll save money on the parts as well as labor, and right now without an income I don't have extra dough laying around. I just don't want to start replacing sensors that aren't bad, either.
Jay (So Cal)
