Ford Expedition Heating Problems
No heat from the front - blower seems ok and have heat to the back
Zvacman
At first the front vents would get stuck on either cold or hot even when changing climate control. However, if you changed the vent setting, it would sometimes change from cold to hot or vice versa. The repair shop replaced the blend door, said the heat was okay.Yes, the heat is okay, but now it is stuck on heat no mater what the temperature selection(hot/cold) or vent selection. Brought it back, They told me a wire was loose and all was okay....Still stuck on heat.... Brought it back and they replaced the panel control for the front vents... Still not okay.... They are supposed to ask around and get back to me. They can't seem to figure it out. Any suggestions?
Raking but not staying in the fixed position the temp control is asking for. Any advise on what to replace? :confuse:
In the front the blend door axles break which leads to no control (in the back it is the blend door actuator that breaks it's gears). Two ways to fix the blend door, the Ford way which is to remove the dash and put in another plastic door. There are aftermarket kits that you go in through the back of the glove box opening with a steel door. Look up Heater Treater, I think their site is heatertreater.com. I haven't had to do one yet, but will go with the second option when the time comes.
