Deleting Emissions Control/sDevices 1992 Rodeo V6 3.1.
Is there a way, or is there a kit available to buy that will enable me to remove ALL w/exception of CAT (exaust system is fairly new) the emissions control devices from the engine, etc. of my 1992 Rodeo and allow the engine to run say as like a pre 1973 vehicle?
Believe me as a Native American I'm all for being green but being on a fixed income as I am, at the truck's 268,000. miles these devices are failing on a regular basis and are keeping me broke (currently engine misses and stalls at low speeds around 1500 rpm and I think it's the MAP sensor).
If the above option is not a possibility, can anyone recommend a pre 1973 SMALL V8 that will fit into my vehicle without too much modification? I don't want to change tranny or rear end because drivetrain was rebuilt shortly before I bought the truck.
Thanks in advance Guys!!
And modern cars are tuned to run with cats, etc. in place, so you may wind up with a rig that runs even worse if you take them off.
Since I can't afford payments either (or I could fix this one) I'll look for something pre. 1973-a 4 X 4 Pickup Sm-V8 W/A Camper top-The next best thing to an SUV I guess. I need something I can work on myself.
