Isuzu Trooper Ticking
climberman
Member Posts: 6
I have a 1996 trooper it had 110000 on it when I bought it. A ticking noise started on the upper end of the motor. I have changed the oil twice and switched to synthetic oil the noise is still there. Someone was saying adjust the valves are there any instructions out there to do that.
SUVs and Smart Shopper
I get a ground at the Dimmer switch, all 4 headlight fuses, Headlight switch, and Headlight bulbs (all three blades).
What I believe are the Hi and Low beam relays have power to them. (Mounted next to each other on the left front next to the headlight.)
I have parking lights and tail lights.
Help Needed Please!!
The intake gaskets on the 3.5 are ridiculous. If you ever get a chance to look at the OEM's you'll know what I mean. Hard Plastic? Yeah, that'll last forever or until it gets brittle. Fel-Pro makes an interesting replacement that should last. It's my only gripe with an otherwise really nice vehicle. Judging from what I saw when I changed mine I can say that everyone will have to do this repair sooner or later.
I don't normally post to forums, but I do search them for solutions----so I decided to share this. I hope it works for you!
I changed the oil again at 120K with 5w-30(with no additive) about 2 months ago. The ticking returned last week (as original) when I purchased the car. I added 1/2 bottle of Redline to the oil and the ticking stopped immediately. I will be adding the Redline to each regular oil change.....proof is in the pudding!
