Service Manual: 98 the same as the 2000?
johnnybravo300johnnybravo300 Member Posts: 1
edited August 2014 in Subaru
there wasnt any service manuals printed for the 98 but ive found books on the 2000. are they the same car? can i use the 2000 book?
i hope someone can help.
oh, im having an issue with power at the starter. i dont know if its a fuse or the ignition or what, and im scared to tear into it without a book.
  • xwesxxwesx Member Posts: 18,242
    Well, they are highly similar cars, but not exactly the same between the two years. I think they did a little bit of tweaking on the drive train. I doubt it would affect the starter components.
    The 98 IIRC has a DOHC engine, by 2000 they had SOHC engines.
    -mike
    Subaru Guru and Track Instructor
    mike is correct, they went to the SOHC engines, so some parts are different.
    The body and most of the car are nearly identical, though. It was only face-lifted for 2001.
  • lmnassociateslmnassociates Member Posts: 1
    A light comes on my dashboard that says Brake P.l
    What does that mean
