Problems with Voice Recognition in your Benz
I am having problems with my voice recognition system on my C350, does not seem to recognize my number 2 most of the times, it recognizes it as a 0..even after doing the voice recognition individualization, it is still failing, apprently I heard this is an issue with most Mercedes Benzes..is there anybody else having this issue? Any comments? The dealer is looking into the matter but this is disappointing for a Navigation system which costed this much and is not able to locate certain addresses due to a problem with recognition or dial a phone number properly..
As for reports of "an issue with most Mercedes.." I recommend that you go to either/both of these websites (MBWorld.org or BenzWorld.org; the largest MB forums in the world) and search for this topic/issue. I doubt much will turn up as I do not recall this being mentioned very often in the forums. Maybe your vehicle has a defect with the onboard microsphone, vocoder, or signal processor and then dealer is trying the old "they all do that" routine. Press you dealer to make it right.
