95 olds aurora Idle problems
Hello i have a 95 olds aurora 4.0 that will not idle below 3000 rpms this just started today any ideas of what may have happend and how to fix
Probably not. The pressure sender is often the culprit. They cost about $25; buy only ACDelco. It is a black cylinder about the size of a roll of quarters located near the oil filter.
If you have to ask where the oil pump is, do not consider replacing it yourself.
Hope this helps.
Les
