Regarding the Arnott-designed rear air shocks - true.
The Arnott shock has no auto-dampening feature. The "sensor" is a resistor that you wire into the dampening circuit.
If you buy the [recently available] Arnott remanufactured GM air shocks, there is no need to use the sensors and these shocks also have lifetime warranty.
I am now looking to replace the GM front shocks with standard shocks and I now need to find out what I need to bypass the dampening system on the front.
Still, in the end I got lucky and just found a new, still-in-the-box, OEM compressor (with the air dryer and factory harness) AND with the mounting bracket that connects to the frame rail (so I don't have to drill out the broken torx screws on mine) AND with the rubber blanket/flap to protect from road grim, AND with the rubber air line/exhaust hose. It was on ebay for $305 buy-it-now . . . so I did.
I'll soak the the three frame bolts with PB Blaster to make getting them off easier (but the new unit comes with the three frame bolts and nuts so if needed I can just cut off the old ones). With any luck (and a air impact), I'll have it in place in 15-minutes including jack time!
Now I'll just wait for the shocks to go and then order the reman OEM units from Arnott.
Thanks for all the help.
Bench testing the relay, apply 12V to terminal 30, run a wire from 87 to ground. Then jumper 85 & 86, you should hear it switch. If not it's bad.
Good Luck
IMPORTANT: Just in case, one more thing to check out and if the fuses are good and the relay is good. Check the continuity on each of the new butt connections for the arnott sensors that you put in place. Then ohm out each sensor, you should get about 25 ohms, if you do not and get either an open ciircuit or a reading that fluctuate then it could be one of the new senors is bad. It happens and of course it happened to me. Arnott sent out a new one immediately.
1.ARNOTT/ BILSTEIN REAR AIR SHOCKS
or
2.REMANUACTURED PAIR OF REAR OEM REAR AIR SHOCKS
If it does click and works then make sure all your wheel sensors are working because the last thing it could be and they do not fail often is the actual ESC module. I highly doubt this is it.
Give me an update on the relay. Good Luck.
I think you said that you have power to the Blue & White, I am guessing that you checked on the car side of the connector not the compressor side. If that's the case then I would check the continuity of the connector itself from each side while connected together. If that's good for all the wires I would leave it connected and nick the blue & white wires on the car side of the connector and jumper them together with a piece of wire. If the compressor starts it the exhaust solenoid. If it still does not start I would check the resistance of the pressure switch but this is a little harder to do since you have to check it while the pump is running. It's a normally open switch but then when the pump is at the correct pressure it should close.
The other thing I mentioned before were the wheel sensors, are those working?
Seems odd that the solenoid would open up and the compressor would be dead, doesnt it?
Traded in 2007 Yukon XL with Premium Suspension (same size rims and identical tires) and am beside myself with how rough the Autoride suspension is. Have complained to GMC and have the Customer Assistance Center involved.
The current ride 'feel' is just the opposite of what it should be: "A pleasing, refined and well-isolated ride."
Is anyone else dealing with this?
Researched parts for Denali vs. Escalade and both are the same (except for Electronic Suspension Control Module - probably to eliminate service department errors when the Tech II is plugged in). Drove a new Escalade ESV. Ride quality is night and day - Escalade rides butter smooth compared to the Denali. Why?????
Have 10 pages of questions, input, complaint, etc in to the customer assistance center @ GMC. Today I should get a call from a rep at the Tech Dept to discuss this issue. We'll see what happens!!!!!!
I have a 2004 Yukon XL Denali AWD and it rides great. Currently have the new Michellin Latitudes P265/70R17 and they ride great. Yukon also has 126,000+ miles on it, but the front and rear shocks are new OEMS.
I can't imagine that the 20 inch wheels (with the small profile) would ride very well. Keep us posted.
Our old 2007 Yukon XL had the same exact tires w/20" rims (factory combo).
There's something definitely wrong with the Denali, but GMC hasn't done anything yet to attempt to find the problem - all the mechanics will say is "There's no fault code so our hands are tied, there's nothing wrong, suspension operates as designed."
First mechanic blew smoke up 'you know where' with the following statements: 1) GMC builds the Denali's more like trucks now; 2) Give the vehicle 20,000 miles to break in the suspension; and 3) The vehicle will ride better fully loaded.
My responses: To statement 1 - If I wanted the ride of a truck, I would have bought one. Besides, why then all the seats? To statement 2 - Funny, our 2007 Yukon XL, same body style, rode perfect from day 1. To statement 3 - It's only my wife, myself and our 2 dogs. When, if ever, will I get the vehicle fully loaded? Shouldn't the suspension operate correctly regardless of the load? I towed my bass boat around and the ride got worse.
No call yesterday from GMC Tech Dept. Maybe today?
"Service Ride Control" (msg on dash)
I've skipped all over and need to find out what sequence I should be troubleshooting this problem before I just shoot myself! :mad:
I've replaced the compressor (w/Arnott)
Bench tested compressor (runs fine)
Replaced blown 40A fuse (Stud 1)
Checked IGN3 10A & RTD 10A (both OK)
Tested Relay by jumping 85w/86, 87 to ground & 30 to 12V (No clicky?)
Jumped 87w/30 on Relay & heard compressor run
Have NOT done anything yet with Blue/White wires on solenoid.
Thanks in advance!!
It sounds like your relay is bad, if you run 12 V to 30 and a ground to 87, then jumper 85 and 86 and no click then it's the relay. When you jumper 87 directly to 30 you are just hot wiring directly to the compressor.
The other test you can do is jumper the blue & white wire on the truck side of the connector on the compressor when is't hooked up to make sure the exhaust solenoid is working.
But from what you said I would replace the relay.
The last two things would be checking the wheel sensors and the new Arnott sensors if the relay does not solve your problems.
Please let me know how it goes.
It sounds like you have no fault messages and you can hear the compressor come on like it should?
You were spot on. My 04 Denali XL's compressor quit working a few weeks ago and I received the "Service Suspension" error on my information center. I checked fuses, power to the pump, etc. Same thing as everyone else. My neighbor was helping me test the system- so we pulled the compressor out and bench tested it. Compressor kicked in when we gave it juice- which baffled my neighbor. I said, "Hey- let's pull this top cover off where the blue and white wires go in. There was a guy on a forum talking about a wire broken off at the terminal." You were right. We tested the coil and we weren't getting any reading. We found the broken wire, soldered it back, tested and we were in business. Re-installed the pump, turned the rig on, and the sweet sound of the compressor was on again. The message was gone as well.
Thank you so much for saving me at least $180 on this fix!
If you are ever in Bismarck, ND I will buy you a beer!!
Thanks again, Tim.
The compressor is usually quiet and usually turns on a few seconds after the vehicle is started. The compressor may need new rubber bushings as well to lessen the vibration which in turn lessen the noise of the compressor. Let me know what oyur find out. I have other leads for you as well.
GMan68
Wheel Bearings
Ball Joints
Shocks
Speed Sensors may need cleaning
ABS Sensors may need cleaning
If you have air ride your compressor may have failed
Let me know what you find.
GMan68
Look at arnott.com and suncoreindustries for conversion kits that include sensors and or affordable replacements for your existing system.
