Off-highway or Off-road capabilities of Venza AWD
On Toyota.com, the spec for Highlander and RAV4 show similar approach/departure angle (degrees)= 29/24. Even RX350 and Honda CR-V have similar values. But the site does not specify any for Venza. However I've found some other sites like fleetrates.com report Venza only has poor values of approach/departure angle, approximately 17/16. I doubt if those figures are correct. If they are correct, does that mean Venza has much poorer off-highway/road capabilities than the competing cross-overs? Any one has those figures for Venza ?
MD
But I just don't understand even RX350, which is so similar to Venza but with lower ground clearance and smaller rim, has much bigger approach/departure angles. Can you explain that ?
MD
a. On a standing start and during acceleration, torque distribution is adjusted to the rear wheels. my question: is that 100% to the rear wheels or is power still being sent to the front? Does torque go to the rear wheels only or is there a rear wheel bias, for example front/rear 45/55?
b. When cornering, torque distribution to the rear is reduced. My question: is that 100% to the front wheels or is power still being sent to the rear? Does torque go to the front wheels only or is there a front wheel bias, for example front/rear 55/45?
c. At highway speeds, torque distribution to the rear is reduced. My question: is that 100% to the front wheels or is power still being sent to the rear? Does torque go to the front wheels only or is there a front wheel bias, for example front/rear 55/45 or more like 90/10?
d. What is it that the system gauges to make the changes, slippage or speed?
My guess would be that with moderate to hard acceleration the torque distribution will be something on the order of 70/30 F/R and only 50/50 with front wheelspin resulting from engine torque having recently ocurred....slippery surface.
When turning tightly, especially in an accelerating turn, the coupling to the rear must be removed entirely to prevent tire scrubbing and/or driveline windup.
At highway speeds on a reasonably tractive surface, say cruising along at a relatively constant speed, there is no need for torque to the rear. And just like with a true 4X4/4WD it could/would be detrimental for both front and rear drivelines to remain engaged in those conditions.
d. Braking, engine torque, roadspeed, turning radius, wheelspin/slip.
also we had a 2009 impreza living up up in the mountains where it snowed 400-500" a year. The impreza bogged so bad in the deep stuff that sometimes we couldn't get home. After 1 year with that junker we traded back for a 2004 audi a4 1.8t and the difference was night and day. The 5 year older audi blew the Subaru away in all aspects. I would never buy a Subaru again. They said it'd get 30mpg. Well, only with a tailwind unloaded. Normal highway was about 24-26mpg and 21 city. We just got a 2015 venza with the i4. Only have 300 miles on it so can't really tell you how it'll do off road yet. However, we did buy it because our 2014passat with 1.8 tsi engine (wich is way more fun to drive) couldn't fit all our camping stuff nor go off road at all. I'll be going camping with a little off road soon and will report back.
The '15 Outback has 8.7" of ground clearance vs 8.1 on the '15 Venza.
Sedans would bog down in my alley at my last house close to Lake Superior in the UP, but I'd have to go hunting for drifts if I wanted to bog down my old '97 Outback.
400" a winter is nuts btw. Most we got in the UP was a bit over 200 and it was rare to get over 50 when I lived in Anchorage (mostly driving a 82 Tercel with a bit less than 5" of clearance). Now I just have rocks on the gravel roads in my neighborhood to worry about.
