Help!Need part for Caravan Power Window Regulator
My passenger side power window in my 2005 Grand Caravan stopped working. Several people mentioned how the problem is consistently an overcurrent protector (or fuse) located inside the regulator. I've followed the instructions and removed the fuse, but cannot find anyone or any store where I can purchase this part. My local Dodge dealer actually laughed at my request. Is anyone familiar with where to buy this part?
woody
This discussion most likely refers to a ceramic condensator
like the one that can be found in the top right corner of
link to condensators img
It is there to minimize disturbances in the electrical system that can be heard as a buzzing sound if you have the radio on while operation the window.
I have verified the switch and motor work. Not sure where the power to the relay comes from? Wiper system works fine if you use the Wash feature. Other than that no movement.
Any help would be appreciated .
Thanks,esf
Mine were bunched up and to just get them aligned again took me all day. I'm afraid it will just happen again and that I may have to buy a new set.
